EOI/FORSALE
I have 2 brand new VELO Podium 2 fixed back Bucket seats, re trimmed by Autosport in Sparco Blue with White writing only pair with this combo.
FIA and ADR approved
Immaculate never been installed comes with mounting brackets.
Also has the receipts too
Looking for around $2500
Located Adelaide
Lewis - 0432581798 or PM
Edited by Volk34
  • Replies 41
i think you missed a few digits on the end of your offer above
great looking seats & crazy comfy!
also will swap for a full neo25 manual conversion with all the bits and bobs
Will Separate $1100 each or both for $2000
Comon guys brand new seats, will change the look of any cars interior from dull and boring to bright & custom
theres are the only 2 seats in the world with the Blue & White custom job out the velo factory
I also have the receipts too
i think these are only ADR approved for 4 door cars lewis......for a aftermarket seat to be ADR approved for coupes they need to be able to recline......good luck with the sale but.....they look f**king aweosme
you just have to register your car as a 2 seater and there will be no issues
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
