120,000k's
Silver
Airbag
Hks 2540 turbo (Hiflowed)
Apexi hybrid intercooler
Hks Air Pod in custom box
Z32 300zx AFM
Big aftermarket fuel pump
Nismo 555cc injectors
Apexi fuel regulator
Nismo oil, radiator and fuel caps
Strut brace / stabilers in engine bay
Custom 3 1/2 inch exhuast system with twin inlet to muffler
OS Giken Triple Plate Clutch
Tanable Adjustable Suspension
Apexi Superbrake cross drilled and slotted rotors all round
EBC brake pads
Tint-a-car Formula 1 window tint
17inch crome Equip Work Wheelswith rears deep dished
Dunlop 235's on front and 255's on back
Nismo clear indicators
Nismo Carbon Fibre door pillars
Apexi 60mm electrical guages x2 with controller unit (boost and water temp with white face) on greddy pillar
Apexi 60mm Power in HP gauge with control unit with white face
Greddy 52mm fuel pressure gauge with white face
Nismo 320km/h 11000rpm complete dash cluster, white face
Hks turbo timer
C's Quick Shifter
Nismo aluminium gear knob
Custom gear boot and handbrake boot
Apexi Power FC with hand controller
Momo racing foot pedals
Custom glove box setup with AVC-R boost controller
Apexi RSM with g-sensor
Nismo crome key
Top of line Brantt alarm system with Viper remote pager with digital display and 1km range
Alpine CDA7893R Bass Engine MP3/CD Player Headunit
Apline Type R SPR-176A 6 1/2inch splits
Serviced every 5000k's
Approx 230rwkw
Only problem is clutch is on it way out will cost $1000 to rebuild the triple plate clutch
MUST SELL ASAP
Contact at 0423 351 754
https://www.sau.com.au/forums/topic/32939-modified-1995-skyline-for-sale/
  • 1 month later...
  • 3 weeks later...
Umm, I am interested. But for someone who doesn't know much about cars. On paper a triple plate clutch is like 2700 to replace.Rebuild it maybe 1200ish. plus labor. There is a similar R33 in the trading post for 22500 230rwkw.How much rego is left and are u prepared to get a RWC???. Before I will talk price seriously I and many oters would like these questions answered. thanks.
im selling the car at $21,000 which is really cheap for a car like mine as u can see in the pics alot of money has been spent. i need to sell the car and need to asap so thats why im willing to drop the price to 21,000. The car will be sold without a RWC as i dont think its possible to get one with a slipping. I was quoted $1000-1100 to fully rebuild the clutch and fitted with labor. At this price the car will not come with the plates either
120,000k's
Silver
Airbag
Z32 300zx AFM
EBC brake pads
Hks turbo timer
C's Quick Shifter
Nismo crome key
Approx 230rwkw
MUST SELL ASAP
Hi,
I'm about to buy the above clutch kit, reading your post your car does 230 KWRW with the great mods. I have achieve 210KWRW with standard turbo and internal engine. Could you advise me is it worth using the triple plate, and it's there problem that lead to such as:-
- Have to rev up to certain RPM for it's to move
- Much heavier then Heavy duty clutch
- Rattle when dis-engaged
Or better off getting twin plate clutch
Thanks,
Jack
the triple plate is cool to have
but can be a bit of a headache sometimes
takes alot of time to get used to, but havent tried a twin plate so wouldnt know the difference
Hi,
Thanks,
Jack
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
