My good friiend is keen on this car , Are the injectors maxxed out , what PSI do u run (be honest) , HKS turbo's are great for high boost what do you run on day to day also when ur ringing its neck??
$23 500 is a lil steep , but well worth it if its a good quality example..
  • Replies 41
Hi Blu32GTR, the injectors will only spike over 80%, only over by 3 or 4 percent. The dual stage boost controller has its standard setting on about 12 psi, and with the launch switch activated the car runs on 19-20 psi. The guys at unique auto sports have set all this up on the dyno and I havent tampered with it, except to turn the boost down a couple of pounds as the days have gotten hotter.
Its just had a new (reconditioned) engine put in under 3k ago, spent over 6 grand and have reciepts for all the work done. reason for replacement engine was incorrect tuning for australian fuel, (modded ecu in Japan) and new tune via power fc is healthy and clean. If price is too much for you I will sell cheaper with standard mags, there is over $15000 worth of extras alone on this car so I think price is reasonable,
Hi again,
the injectors are standard as far as I know, as is the fuel pump. The 265's are michelin sports and they have about 60% life left in them. They are a good tyre though, and I haven't seen any wear since I brought them 3k ago, second hand when I got the mags. the fronts are only 5% worn if that, and have heaps of life left in them. 216 rwkw was made @ top boost, at about 6000rpm. Obviously the pneumatic turbosmart system is inferior to an electronic boost controller and the ebc will net a better power figure and curve when installed and tuned correctly. You can pick up a boost control kit for the powerfc which is excellent and allows boost changes via the hand controller. They are about $450 down here, but they may be a little cheaper up in qld..?
shan
If you look at the dyno sheet it actually made 216rwkw @ only 13psi....which is very impressive, if the turbo could be sorted to hold boost to redline it would probably make and extra 30rwkw....might be as easy as a HKS actuator $150 from greenline.
Nice car, great buy.
Hey BOOSTD your right, I just figured out that I've been looking at the sheet wrong the whole time!! Yeah The car still has lots of potential, may as well go electronic boost controller that should fix the problem, although HKS actuator would help with this setup soon.
yes, boost comes on quick, you gotta be very careful in the wet. I love the response of this turbo. Ive raced a Datto 1600 which had 190 rwkw (and was considerably lighter) but just couldnt get me because boost didnt come on for him until the last 2500 rpm in his rev range. Lag sucks huh? Anyone want to hazard a guess as to what sort of power increase I would get with an extra 7psi up top?
"$23 500 is a lil steep" please keep the comments to pm only and not in the main post. Steep? based off what?
1993 r33 gtst manual for $17000 with 60,000 on the clock +
Apexi bar and plate intercooler $1200
HKS gt2530 ball bearing turbo $2000
exhaust, including wastegate split dump pipe $500
18 inch Chrome DTM's with 265 rubber on the rears $2000 at least
GTR bodykit (front 400r bar, side skirts, GTR wing) $1000
Autometer boost gauge + Tomei air fuel gauge - mounted on dual side pillar pod $500
suspension
Short shift kit $400
Performance 6 puck Clutch $800 at least
HKS turbo timer $150
Apexi powerfc with hand controller $1500
Pioneer mp3 cd player $500
GFB stealth bov $350
HKS pod filter $200
Turbosmart boost controller with rocket launcher switch $300
spare R33 GTR front bar $500
$28,900
and you get all that tuned (which costs a lot too) for $23,500
no i dont know this person, merely pointing out that some people expect to much
still think its steep?
those are very conserative prices and dont include fitting and turing
intercooler supplied and fitted will be around 1600, the turbo would be $2500 fitted (or more)
and it looks as though he is using a Tanabe Racing Medallion muffler. Which arent cheap too..
Yes Tanabe muffler it is. Thanks paul, its nice to have someone point this out besides myself. Pics sent to mike J, but email is full... empty and I'll send you more
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
