  • Replies 50
a-pillar trim sold
2 sets of genuine Rays valve caps, blue in color $40 per set of 4
Stock 33 gts-t thermostat - $50
R33 S2 drivers side arm rest plastic - $40
R33 stock sway bars $50 for the pair
Nissan air purifier $20
drivers side arm rest plastic SOLD
  • 3 weeks later...
Great Christmas presents!
  • 1 month later...
