Hey Rush, how r u going? WoW nice work man.
I seen this car in person nearly everyday Parked at ur work place where u took most of the pictures at looks really nice. Didn't knew u were posting it all up here too lol. We have not met even though we work in same street n probably i spot u every now n then driving ur 34 Black matte.
Great work man
  • Replies 161
Great work man
Hey bud,
Thanks for that, where abouts do you work? What's your 33 look like, i might have seen it around also
Oh i am usually at the workshop infront of asianstar/crimesafe.
My dads a panel beater & uncles a mechanic. I just help them with managing all the paper work n stuff.
& my R33 is not registered yet i drive it in the street with trade plate sometimes though but its parked sometimes infront of the shop so if u pass the crimesafe building on ur left u should see it parked on right side. on 29 Meadow ave.
Looks great dude!!!! Especially with the new wheels.
I was in Europe earlier this year and it's a massive craze over there, especially in Germany/Austria. Spotted heaps of Matt black cars, BMW 5series, M5, X5, M3's. A few Matt white cars, Range Rover sport (looked strange) and Cayenne's. The best colour I saw by far was a Matt Green Porsche 911 turbo.... I wish I had the cash because id definetly by getting Matt Green.
Does anyone know who does wrapping in Melbourne?
Z-tune skirts and rear pods, and most likely top secret gtr style front bar with diffuser :P
already have Tein Super streets in there
The Z-Tune body kit is just the front guards, front bar, bonnet and rear wheel arch guards with Nismo Side Skirts and Rear Pods :woot:
So yeah, Nismo.
Top Secret front bar would look nice as well as it gives a more rounded look then the Nismo / Z-Tune front bar, being more straight cut style.
Both are good.
The Z-Tune body kit is just the front guards, front bar, bonnet and rear wheel arch guards with Nismo Side Skirts and Rear Pods :P
So yeah, Nismo.
Both are good.
lol, ok ok, nismo style, lol
yeah i've been eyeing the top secret gtr style for ages, looks porn! pretty exxy though, but worth it i think.
but first up is a JJR black edition return flow front mount!
needs eye lids! needs to be darker, wide body kit and darker black :P
looks good tho! very straight body
U wont get a darker matte black, but at night yhe thing goes near invisible!
Might consider custom makong up some mattr black vinyl eyelids, maybe
The Top Secret front bar sits flush with the front mount intercooler, which makes it look so damn great!
+ the vents and grill are slightly curved to give more of a Stylish look then an Aggressive look to the Nismo / Z-Tune.
Yes I like them both :D So which ever 1 you get, it's a :) from me!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
