hey guys,
things have come up and i need to clear some debts so unfortunately im selling my white evo 7. i've had it for 2 1/2years now with the car been on and off the road because my engine blew up while my tuner was tuning it. he told me a metal flake (showed me a 3x3mm metal flake) got clogged in my injector from dirty fuel (not sure why the fuel filter on the fuel pump missed it?), only recently got it tuned in sydney by micks motorsport. the car has 71 XXXkm on the clock but the engine was fully rebuilt at 64 XXXkm as a 2.3L stroker. i've tried to keep the car as stock looking as possible to avoid problems.
ENGINE:
Ralliart head studs
Mahle forged pistons
Spoon forged rods and bolts
ARD 2.3L forged crank
TD06SL2R 20G turbo
Brian crower valve springs with titanium retainers
bigger hydraulic lifters (stops ticking)
780cc Siemen Deka injectors
Walbro fuel pump
HKS 272 inlet/exhaust cams
HKS timing belt
HKS M40 spark plugs
Ralliart ignition leads
Bigger oil cooler
New bearings
Beatrush cooling panel
Balance shaft kit
Apexi air intake with genuine apexi enclosure
Trust style upper intercooler pipe
Greddy Type S bov on a hks flange (can supply a HKS Racing II for extra)
metal intake pipe
Tomei dump and front pipe
3inch hi flow cat
Xforce catback
Cusco oil catch can
B&M Short shift kit
Heavy duty clutch (installed 9000km ago)
Haltech PS1000 (no afm)
Haltech shift light with custom holder
head serviced, whole engine stripped apart cleaned, full gasket kit.
car was tuned in canberra and made 252kwatw on 20psi with 492Nm of torue (timing was retarded ALOT) but the tune wasnt good as it hesistated on take off, bad cold starts,etc. So i took it to micks (10th of june) who made 248.5kwatw 21psi (forgot to get a print out of the torque) but now the car runs perfectly now. mick made 270+kwatw with 25psi but i asked him to detune it because i didnt need that much power and wanted it to be a safe daily driver.
WHEELS/SUSPENSION/BRAKES:
Enkei tarmac rally rims 17x8 with REO1R potenza's with nitrogen
Whiteline front and rear sway bars with whiteline front and rear end-links
DBA 4000 Front and rear rotors
EBC red stuff pads (front and rear)
INTERIOR:
Defi Boost and oil pressure gauge with control unit II, 2 defi warning lights (boost and oil)
Monster dual pillar gauge holder (60mm)
JVC single din head unit 3.5inch colour screen, plays DVD, avi, divx, mp3, etc. with ipod cable so direct control through head deck.
Apline 6x9
Rhino alarm, shock sensor, glass break sensor, boot/bonnet/door triggers, microwave sensor. the alarm is also controlled via sms, lock/unlock, with a fuel cut - so if someone has your keys and has dis-armed the alarm you can sms it and cut fuel. also sms's you if the any one of the triggers has gone off (tells you which one), if no response it will call you. the alarm will be, reprogrammed for new owner.
EXTERIOR:
Genuine evo 9 rear bar (brackets, lights, etc)
Shaved boot lid.
i've also got some other parts that i'll sell for cheaper with purchase of vehicle in the for sale section.
Volk GTC 19x8.5 inch on brand new federal 595evo tyres
ganador led mirrors
evo 7 spoiler
evo 7 ecu
arc gear knob
moonface gear knob
car has had all oils changed at 40k with full synthetics (rear dif, gearbox, transfer case), engine oil is always changed at 5000km intervals with K&N oil filters except the last one as they didnt have them in stock. will throw in a bottle of full synthetic with a K&N oil filter with sale (oil change no due for another 4000km). I've put well over 30k on this car which i payed 30k for 2 1/2 years ago, chasing $35k
pm me or contact me on 0401573850
cheers
Edited by Icey_Cold
https://www.sau.com.au/forums/topic/330730-white-lancer-evolution-vii/
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
Nice evo, and nice without the wing too!
Im actually looking for a 33GTR, was orignally looking for another 32, I would actually be pretty keen to have a closer look at this in the new year, pm me contact details
Cheers,
Ben
$24,500 without defi gauge/holder/warning lights.
and
$24,000 without the rear bar.
and the stock wing be supplied with car.
email me at [email protected] if interested.
thanks
Edited by Icey_Cold
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
