Just did my tax return. My 33 is sick :)
Harmonic balancer came loose... need a motor.
Anyone got a good running engine for me? Wouldn't mind it coming with a decent standard turbo also... Or does anyone know anywhere good to get my engine reconditioned at least?
Cheers.
https://www.sau.com.au/forums/topic/330770-tax-time-need-engine/
red r racing have got some mental builds going at the moment.
contact them to see if they have something done that you could do a changeover with. Im getting my old r33 engine built there at the moment and was looking to sell when finished, pm me if your interested.
defiantely get ur own engine rebuilt man.
take it to sabadins in clayton.
if u go buy another engine u have no idea what the f**k ur buying dude at least with ur engine u know whats wrong with it and can get it fixed.
a standard rebuild is around 4000+ then if u add a lil flavour to it, maybe a turbo kit (just a lil one) then around 10k (this is with all brand new parts and nothing chinese etc)
ur best bet is to speak to ur mechanic and see what he says.
if u dont have a mechanic there i already mentioned one further up the page who i will only ever use but there are many around melbourne who are very good
can pickup a wrecker engine fitted for less than $4k
and you can have the comp tested etc to make sure its a healthy engine
ring vicroads to tell them change of engine and you will have it sorted straight away
plus rebuilding takes time, unless your going forged not worth it
generally they should give you warrenty
but if the engine still is in a halfcut (just buy the enigne, and return the rest) they are able to start it up with a battery and some fuel
which would be the best way to do it
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
