My current b pillar window seals look like Clark Rubber specials, I knew they looked haggard but yesterday tried to wind down the rear windows and found the seals wouldn't allow it :nyaanyaa:
Highly doubt they are still available new (please prove me wrong), will settle for good cond used if anyone has any they would like to sell.
I think another member ordered the whole 1/4 window off yahoo.jp or import monster (the seal wnt be new, but still in heaps good condition)
I reckon someone should get a custom batch made up, do a group buy. (I would even buy a set for my coupe when I eventually get one)
Recently DR30 parts have been listed on eBay. Seller was in SA. Marc or Dennis may have his contact details, I think they've bought parts from him. Looked like he was parting out a car.
JH
J,
When do you need these rubber seals for?
I'm putting together an order on KRS at the moment and if your interested and can wait till it's done, I'll bring in a set for you in the same carton.
Cheers,
Dennis
I bought new seals from Nissan a few years back and they weren't hideously expensive - but the part I couldn't get was the metal frame that runs on the front edge of the window (mine were a bit rusty). Apparently it's sold as part of the window glass, and that's NLA...
We managed to refurbish one of them and I got hold of another window which had one in better (not perfect) condition. I need to do some more work on it, because surface rust is starting to show.
  • 5 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
