Decided to strip a complete Rb26 that needs a rebuild. Has low compression on 2-3 cylinders
Was running before removed from car in Japan. I have not seen or heard it running myself. so all parts as is.
Short block c/w crank, rods, pistons, cradle, oil and water pump $575
Sump $175
Head c/w stock cams and valve train $650
Cam covers and front cover, no coil cover $250
Inlet plenum and throttle bodies $450
Injectors and fuel rail $175
CAS $90
Ignitor $90
P/steer pump $80
Alternator $70
Air cond compressor $90
Coils and harness $125
ECU wiring harness $250
ECU stock $110
Knock sensors $75
Engine mounts $50
Oil cooler $70
Turbo's pair $350
Exhaust manifolds $100
Dump pipes $90
Heat shields $90
Turbo inlet piping $125
Twin turbo piping $75
Turbo Oil and Water Lines $140
Clutch fan $50
That covers most parts. Prices neg. Better package prices
If you want the complete package PM your offers
Will ship interstate. Small items thru Aust post. Large items thru www.transdirect.com.au
Pick up post code 4165 Brisbane Queensland. You can get online freight quotes with either service.
https://www.sau.com.au/forums/topic/330900-stripping-a-complete-r32-rb26/
Parts and price update
Short block c/w crank, rods, pistons, cradle, oil and water pump, harmonic balancer. Needs rebuild std bore had water in no2 $575 Now $400
Sump $175 Sold pending payment
Head c/w stock cams and valve train $650 Sold pending payment
Cam covers and front cover, no coil cover $Sold
Inlet plenum and throttle bodies complete No TPS$450 Now $400
CAS $90 Now $70
Ignitor $90 Now $70
P/steer pump $80 Now $50
Alternator $70 Now $50
Air cond compressor $90 now $50
Coils and harness $125 Now $90
ECU wiring harness $250 Now $200
ECU stock $110 Now $100
Knock sensors $75 Now $30
Engine mounts $50 Now $25
Oil cooler $70 Now $50
Turbo's pair $350 Now $250
Exhaust manifolds $100 Now $60
Dump pipes $90 Now $50
Heat shields $90 Now $50
Turbo inlet piping $125 Now $90
Twin turbo piping $75 Now $60
Turbo Oil and Water Lines $140 Sold pending payment
Clutch fan $50 Now $30
Head sold and picked up.
Make me a offer on the complete short block. You might be supprised. Want it gone
Someone must want to rebuild a forged bottom end while keeping there car on the road
Hey Darrin: I'll take the front cam belt cover. Please PM me with contact info. Cheers, Rick.
Sorry sold
This is what is left
Short block c/w crank, rods, pistons, cradle, oil and water pump, harmonic balancer. Needs rebuild std bore had water in no2 $325 pick up only
CAS $60
Ignitor $60
P/steer pump $45
Air cond compressor $50
Coils harness $50
ECU wiring harness $200
ECU stock $100
Knock sensors $20
Engine mounts $25
Oil cooler $50
Turbo's pairNow $250
Exhaust manifolds$60
Dump pipes $50
Heat shields $50
Turbo inlet piping $75
Clutch fan $20
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
