Numerous light coats worked on my tail lights, produced even finish ( and not to dark either ) looked a bit shit though so i polished it off with plastic polish. Use VHT niteshade. Sell it at work for about $16 a can. Each to there own though.
https://www.sau.com.au/forums/topic/330914-smoked-lights/#findComment-5376209
Ive used nightshades on a few previous cars like my soarers, this is what happens when you use too much lol, you could only see the taillights at night,bit too dangerous but looks shithot!
https://www.sau.com.au/forums/topic/330914-smoked-lights/#findComment-5377831
using vht night shade 10.00 usd a can here
ya do a light coat let it dry / cure and wet sand w/ a 1500 grit sand paper. suggestion I wouldn't go more than 3 coats.
for it gets stupid dark. That is unless you are planning to replace every exterior bulb on the car w/ LEDS then it might be ok to go more than 3.
It's illegal here in the US too, but I am planning on using vht on every light housing on my s13 including headlights and instrument cluster. as well tint all the windows. ;p
I like that murdered out look.
^ needs about 2 more inches lower. ;p
Edited by jus skott
https://www.sau.com.au/forums/topic/330914-smoked-lights/#findComment-5382018
I wouldn't go near windows with tint spray to be honest as its very easy to f**k up a surface so big... Best to get them properly tinted
Yeha the windows are getting real tint, not the vht. I might do a lot of Janky things but that is not one of them :laugh:
https://www.sau.com.au/forums/topic/330914-smoked-lights/#findComment-5385466
good choice.. last post just read like you were going to..lol.. would have been interesting to say the least.. ps love murdered out looks on cars..... HAve you ever whatched Rob + Big? Love there matte blakck cars
https://www.sau.com.au/forums/topic/330914-smoked-lights/#findComment-5385478
naw I really don't watch much tv at all. other than when I am hanging out w/ my pops.
Time is mostly filled w/ school work for my associates, work and a little sleep. Maybe once a week I have about 2 hrs to go to local car meets.
but imo murdered out cars are def where it is at. well that is until one of your x roommates friends doesn't see your car under a street light and accidently rubs against the drivers side 1/4 panel. lol
https://www.sau.com.au/forums/topic/330914-smoked-lights/#findComment-5385510
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
