Point being? ^
These have a 12 month warranty, the idea of that is that if it breaks within 12 months you can get it replaced. Yours broke within two weeks, so you still had a little bit of time before the warranty expired.
point being if you want to keep changing it when it cracks and new gaskets and studs(maybe if your unlucky), i did change it over once then removed it for a different one
Edited by PaulosECR33
  • Like 1
A gasket can be used more than once you know.
You got unlucky. They are alot better than they used to be.
I had one on my R33 that was regularly tracked, and daily driven. No problems with mine at all. Bar the initial boost creep that was a fault of earlier designs.
I changed mine, however for different requirements.
Which one didn't tighten, one of the four top bolts or one of the two bottom nuts? I've got all 6 in place so it's certainly possible with the JJR front/dump.
I WD40's the bejesus out of mine before pulling them out and then trial tightened the bolts and nuts in fully (without the dump) to make sure they'd go all the way in without problems.
the middle bolt next to the engin block i recon i need a bent open ender (half moon spanner)
Strange, I thought I got that one open & tightened fine with a long socket. Or maybe I used a uni joint. Can't remember...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
