Hi,
Quick story i had an engine rebuilt, the plenum was faulty (cheap china...so replaced with genuine greddy) but before it could be replaced my oil filter blew off...interesting...took to mechanic he tried a couple times same result...we both put it down to faulty relief valve in pump.
A new geunine N1 pump arrives...goto install that...installed then to have a look in the oil pan to find an oil squirter and one of its brothers detroyed next to it...so I'm wandering what is actually involved in replacing the oil squirters in an rb25.
All this was done at the mechanics and I will be talking to the engine builder but I just want to get an idea myself as it looks like they were either installed the wrong way (pointing down) or from an rb20?!?
Cheers
https://www.sau.com.au/forums/topic/331856-snapped-oil-squirters/
I'm sorry but your mechanic with the oil filter is probably not too bright. He is probably using the wrong threaded oil filter. These will seal up to 200psi so it's not likely to be a faulty relief valve. Have never seen one as yet and the engine builder should have checked that anyway.
The squirters on a 20 are the same as a 25 and they can be broken if not installed correctly or if the piston is put in back to front.
Either way, the engine builder needs a talking to
Thanks for the reply...as for the filter it was a genuine nissan and the gauge could only read 150psi, they tried 3 times and the same result...as for the engine (as i just want to get an idea) that would require removing the head to get to the nut that holds the squirter correct?!?
Will the complete engine need to go through an entire cleaning process due to metal fragments everywhere or just hope on the filter picking it out :( not taking into consideration that the squirters may have damaged the pistons...
haha don't mention the word rebuild...I only clocked 500ks on it and that was babied, highest rpm would have been 5k
and I would have to agree turning it over by hand would have been the first thing to foul...maybe incorrect torque setting and then when put under load has come free...either way I'm still waiting on reply from builder as it was done interstate :(
It probably needs to be rebuilt, sounds like some serious issues with it to be honest.
I would have thought spinning it over by hand after the rebuild would have revealed rather quickly that the squirters were wrong.
incorrect clearance may snap them also, ive seen Arias pistons snap these quite often as was the case in my 25 with previous builder not ensuring at least 2mm (80 thou) clearance. Engine will still turn over by hand but will strike oil jets once rpm, piston expansion and rod stretch come into play. To obtain correct clearance aluminium or copper crush washers are used but must not be too thick as to shorten crank counterweight clearance.
yes engine builder id hazzard a guess is a novice.
Edited by blitzxtr
The rep of the builder is quite good (not going to mention openly on forum) so I'm a little shocked about it...and the pistons are JE Forged .5mm over
thats definately not the way to run in an engine. If your builder advised you to do that id be very concerned.
No those were the ks I put on after the run in was done on the dyno.
ahh, sweet. Check the piston skirts for marking, if its in one spot id suggest incorrect clearance. If its several marks moving around id say they were not torqued. 25ft/lb for those puppies :(
gonna need almost a full strip down to check and replace.
the oil filter is a wierd one, wat oil filter is it? Z145a? or something else.
Well it looks like there wasn't enough clearence on the pistons for the squirters and will be completely torn apart to find the rest.
The filter was a genuine Nissan.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
