Motec M800 wideband lamba enable and datalogging
Full Loom with all the sensors
The custom loom has been marked for easy install (set up for rb25/26)
Bosch Super sports 491 leads
Bosch coils
CDI AEM Ignition module
Basicaly this stuff is all new or seen very little use,I picked it up for a project car that i have since sold as of today.
The motec has been tested and is unlocked in perfect working order.
I will fully refund any ones money if there is any problems at all with this gear.
To buy all of this stuff and have the added extras opened on the motec will cost you over 6g
Every thing is in perfect working order and is as new so grab your self a bargin.
My motec installer told me i did not need to buy a single thing every thing is here and ready to install.
I would post pictures but my phone wont connect to the pc,If any one wants pictures of the gear im more then willing to send them via text
Price $3850 ono
Trust Greddy T517z's
Serial number 021008012
Direct bolt on replacement for your gtr skyline.
I picked these up for a project that was sold today,One turbo was damaged so i simply had new cores/cartidges put in both turbos
Again these turbos are bascialy new and have had no use at all since rebuild.
Comes with acuators drains and so on,Also ill throw in the old cartridges and spare parts,There would be enuff parts to rebuild one turbo if you ever needed to.
These turbos retail new for around 4 grand
Price $2850 ono
Edited by Gtir-keiron
What size rear on the T517Z's? Also, what were the new cartridges, from Greddy/Trust or MHI equivalent?
Mike
the cartridges came from jpn mate.
I just paided a performance mechanic to put them together.
Ill have to check the rear on the t571zs is there any kind of marking i should be looking for mate?
They will have a 8cm or 10cm exhaust housing; should be on the casting. Can you post some pics?
They are 8cm rear housing mate approx 360 hp worth around the same 25/30 hks turbo
pms replied.
Please stop the lowballing on the motec guys every one knows what its worth to buy and have all that stuff upgraded.
Even in the 2 upgrades alone with the motec unit and just the upgrades your out of pocket over 4g.
If your really keen on the best computer on the market for your car with all the extras shoot me a text or give me a call on
0427284275
Is the aem a 4 channel or 8 channel, and would you consider seperating?
I don t really want to mate if i can help it.
Id rather sell the package complete.
Enable M800
Hi/lo injection
Lamba Single
Logging 1M
Servo control
LSU4.0 (6066) Lambda sensor3 bar MAP sensor2 x 63CP0220 - 250AUNAOC TI or Honeywell sensors (oil and fuel pressure) approx $200 eaDelco Air Temp sensor (Brass)Bosch Engine Temp SensorMotec Mx00 series wiring loom6 x Bosch supersport ignition leads AEM 2801 4ch CDI6 x Bosch EL faclon coils (with bosch LJET 2 pin plug connection)
My motec dealer just price listed every thing up and the grand total is just over $6500.00
So grab your self a bargin at near half the price for as new items.
Enable M800
Hi/lo injection
Lamba Single
Logging 1M
Servo control
3 bar MAP sensor
6 x Bosch supersport ignition leads .
bump
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
