cause i have that much money to do a conversion >.>" lol
so for my tune 10psi yes? if it breaks on the dyno i can blame you's guys ok? good :worship: keeping in mind this 25 has 183xxxkm's on it? 10psi still recomended?
its just i can afford another 2nd hand motor but i just cant be farkked having to do a engine swap if it goes bang while being tuned -.-"
  • Replies 54
+1 for sticking in 12psi. Why bother with engine management if you arent going to stick in some proper boost and make the most of it.
here's where it got me. 277atw :rolleyes:
http://www.skylinesaustralia.com/forums/Rb...79#entry5379379
lol i dont think i'll go that far, but thanks for the input anyway! errm another question to ask. ive just got a power fc and im going to get the car tuned fairly soon, how much power from standard will be looking at?
mods ive got are:
fmic
splitfires
split dump with 3" piping all the way to a cannon (no mufflers)
boosting 5>7psi
Edited by jjman
If you want to strip out your car, then do as I'm doing ;)
Rip out all the interior
and remove the glass from the windows
lol! nice mate, i bet that makes a noticable diffrence! :P some how i think cops would be questioning where my interior has gone... =P
"i spilt coffee on it officer :) so i pulled it out to be dry cleaned"
"i spilt coffee on it officer ;) so i pulled it out to be dry cleaned"
Yeah, the cops noticed it didn't have much interior, and a half cage, but didn't believe me about the coffee either :)
reo bar in the bumper is good for about 6kg, but it becomes illegal once you remove it as you have compromised the front end....6kg doesnt sound like heaps.....but its at the very very very front, makes a slight different, ac can go, so then can the condensor, boot trims, spare, jack etc. rear body trims, then it starts getting difficult...wat luxuries can you live without......how much time you going to spend driving....its all bout compromise at this point....lighter seats..removing non-essential bolts is good at removing a few kg, but then you drive down the road thinking....is my gearbox going to drop out coz i took out that many bolts....so i dont recommend it....lighter rims, lighter lug nuts (can be good for a kg in total), carbon fiber boot and bonnet,....thats about the MAX you'd go for a street car....
the entire ac system was good for 24kg in my 84 ma61 Supra (so compressor, brackets, condensor, drier, front end lines)
Edited by woggin
For sure ^ You don't need a floor either. Cut that bitch out and just hang onto the steering wheel.
Lol, reminds me of the first fast n furious when that super street spec chequer plate goes flying.
Danger to teh manifold.. lol
As for real weight saving the guys have allready said all the easy street spec stuff,
your next step would be replacing all glass with polly, replacing big metal fuel tank with a fuel cell. Ultra light battery, carbon shafts, Ti exaust, Stripped loom and the list goes on..
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
