hey,
I'm about to do a suspension upgrade on the R34 GTT and I can't decide between a few things.
Basically the car is a daily driver so I want comfort but i want to be able to go for a run through the hills or to the track if i ever wanted.
so I'd ideally like a spring/shock combo with sway bars.
I've seen this on the old ebay:
http://cgi.ebay.com.au/Nismo-R34-upgrade-S...=item335f0b9e27
Has any had experience with this? is it worth it? seems cheap.
Otherwise I was thinking either KYB/King springs combo or bilstein/king spring combo with whiteline sway bars.
Otherwise there is the possibility of BC coilovers with softer spring rates perhaps.
Budget is $1500 - $2500
What spring shock combo should i choose? what size sway bars front and rear?
I know this has been asked 11billion times before but I'm still unsure on what to get.
Cheers
https://www.sau.com.au/forums/topic/332086-r34-suspension-choices/
I'm thinking similar as you man and keep wishing the sydneykid bilstein kit was still available or someone would decide to sell it 2nd hand. That ebay stuff looks pretty good no idea how good they are. Springs and shocks with upgraded swaybars seems to be the go with a daily driver with some track work
Give heasmans in Sydney a call mate. Apparently they still have limited stock of the sydneykid kit available. (another member on here picked some up not long ago)
Seems i've decided to grab some greddy type s that came up for sale on here. little bit less messing around and a bit cheaper than buying new - and from all i've heard are a great coilover even on the street.
Now it is just decided what swaybars I want.
ie: what size front and rear and whether I want adjustable or not.
Anyone feel like chipping in on that front?
Edited by stenve
+1
I bought some from heasmans only a few months ago, he had them in stock and sent them straight down. Didnt sound like it was the last set or anything.
I bought the adjustable whiteline swaybars and really use the adjustability of them. You can gradually fine tune the car to how you like it. Then you can be silly and make it oversteer like a whore if you like to drift on private tracks!
Im very happy with them but havent tried any other ones so cant compare.
ahh you were the one I was thinking of with the Heasemans and bilsteins.
so i've ended up buying a set of greddy type S coilovers and will be ordering 24mm front and 20mm rear adjustable bars
So i'll have new adjustable castor arms, alloy subframe mounts, solid steering rack bush, swaybars and new coilovers all going in soonish :worship: should be fun
What holes do you generally have your swaybars set on front and rear Harey?
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
