Hey everyone, I picked this up the day before yesterday for a trade of my XF ute and a bushbasher XF with a good engine and a 5 speed. My mate that traded it to me had no need/want for it and was green with envy as another one of our mates just bought an XH ute with a few mods that has 199.1 HP at the treads and now he's in pursuit of a fun ute aswell.
It's a 98 model VT (if you don't like the fact it's not a skyline, don't post please)
Good points:
GETRAG 5 speed manual from factory
Good paint
17's
New tires
Everything is in good condition, no bumps/rattles etc (it's rattle less than my AU)
Bad points:
The GETRAG needs to be recoe'd/replaced
Apparently the springs in the back are worn and make it unstable at speeds of 140kmh + (I've had it to 140 and didn't feel anything untoward, private road ofcourse) so is this an honest reason to make a car unstable? It really seems to handle quite well and I couldn't fault it, but maybe I was just lucky.
The getrag makes horrid crunching/spinning noises going into second and all the other gears if you get up it, you can make no noise in any of the gears if you drive like an absolute grandmother. Because I have no idea wtf is wrong with it, I won't be driving it until it's fixed.
My plans are to fix/replace the GETRAG, lower it, put a stereo in it (the old one was taken out), give it a good clean as it's filthy, and sell it to buy something else, VT's aren't my favourite car.
Here are some pics:
So once the gearbox is fixed, I am confident that there is absolutely nothing wrong with the car, it starts first go, has 212xxx km, handles great and has a 5speed. How much do you guys think I could fetch for it? It really is in great condition apart from the gearbox.
OH and it has a new clutch :verymad: I think I got a good deal.
https://www.sau.com.au/forums/topic/332146-new-car/
Back to boostcruising please..
I think you should head over to booscruising, considering you can't punctuate your post with a comma. I don't like commodores, this is just a way for me to make some money to go toward a skyline, I have no intentions of keeping it.
https://www.sau.com.au/forums/topic/332146-new-car/#findComment-5388192
Maybe $4000-$6000? Being a manual is a bit rarer since most VT Executives are autos.
Just look through carsales prices I guess.
Thanks mate, I was thinking the same. Definitely an easy dollar, considering I was going to try and get rid of the ute's for $900.
https://www.sau.com.au/forums/topic/332146-new-car/#findComment-5388196
If it is in good condition and you get the manual all sorted I don't see why you couldn't sell it for $4000. Like I said, look on carsales for a similar condition/spec car and see what people are asking. Then maybe put it up for sale for a bit cheaper than every one else for a quick sale.
https://www.sau.com.au/forums/topic/332146-new-car/#findComment-5388220
Definately be able to sell it, as P platers would love it, being a manual!
Yeah mate, that's my target market :verymad:
Cheers man. I'm gunna clean her up next weekend after I get the box out, probably gunna change the trims between the front and rear doors on the outside of the car as they are faded, put a stereo in it and replace a hazard light button that it's missing and put it up for $5,000 and see what people will say. Carsales has some decent examples for between 5 and 7k, so I think I'll make a killing, considering it cost me pittance.
https://www.sau.com.au/forums/topic/332146-new-car/#findComment-5388233
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
