Sold my R33, now clearing some spares and things I found during cleanup.
Item 1
HKS Mushroom pod filter with AFM adaptor and brackets. Used, in good condition. Will be cleaned ready for re-oiling or can buy new replacement filter media. This came with my car, but I swapped it over for standard airbox.
Price: $60
Item 2
Universal fixed back racing seat. Comes with bride sliding rails mounts directly into R33 (and R32 I believe). Used twice, has been wrapped in plastic so very clean and no damage. Padding is as new, not worn at all.
Bride Rails include standard seatbelt clip and wiring harness for seatbelt light on dash.
Price: $180
Item 3
Full set (4 off) R32 GTST rims fitted with Bridgestone RE540s SEMI SLICK tyres. Tyres are 1 pair 205/50 R16 1 pair 225/45 R16. Good for another run or skid pan, emergency spares whatever. Rims could do with a bit of a clean, will suit R32/R33 maybe R34 and other cars with 5x114.3 stud pattern.
Price: $180
Item 4
Full face Helmet with visor, size L 59-60cm. Brand is KBC and says "VR1 Euro" on the back. Meets AS1698 standards. Basically brand new, I got it but doesn't fit me very well (too big for me), no scratches or anything.
Website Review: http://www.motorcycle-accessories-wiseguy....ws-KBC-VR1.html
Price: $80
Item 5
R33 Gtst pair of front rotors. Bought these off another forum member as precaution for RWC, didn't end up needing them so no longer of any use to me. These are used (slightly) and are at max thickness still - 30mm.
Price: $140
Item 6
Fitted Car Cover to suit R33 coupe. Autotechnica brand "Stormguard" type, fully waterproof outer and padded inner. Uses straps under the car to keep secure and has elastic sides, very snug fit. Was only used on clean car, inner is not stained and exterior has no markings or damage. Used rarely, car was normally garaged so only used on odd occasions.
Website:
http://www.autotecnica.com.au/covers_carcovers.html
Same one for sale as example
http://cgi.ebay.com.au/AUTOTECNICA-STORM-G...G-/140421611530
Price: $75
Item 7
R34 standard SMIC. Good condition, comes with shroud and all mounting brackets. Direct mount up to R33 Gtst, no modifications required.
Price: $70
All parts are located in Melbourne outer east suburbs 3153. Most items aren't really suitable for posting, would prefer pickup. Pics below, can take more at request.
PM or sms/call 0403 509 483
Edited by R.C
https://www.sau.com.au/forums/topic/332281-fs-r32r33r34-parts-and-misc/
ok, will check out.
I probably wont be able to check emails/calls during work today so will reply to messages tonight.
Hi All,
Firstly, thanks for all the interest. To answer some FAQ:
Location of all parts is 3153 in MELBOURNE
There is one seat for sale only, not a pair.
Would prefer local pickup, most items are bulky and not easily/cheaply posted.
I will be OS from 15th Aug until 27th Aug, if you wanted something fairly soon best would be to organise pickup after 6pm weeknights or by appointment on Saturday.
I am attempting to reply to all PM's but have to wait 5 mins between each reply so appologies if I miss anyone.
R34 SMIC sold pending payment.
Everything else still up for grabs.
Update:-
R34 SMIC sold.
R34 SMIC brackets and shroud available, buyer did not want them.
$10 or free with another purchase!!
Last chance to pick up today for another 2 weeks, get in quick if you want something!
  • 4 weeks later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
