Item:
RB20DET, re-built motor, mildly worked.
Website: here and other forums
Item Condition:
Motor was running fine before removed from my car, Inspections are welcome.
Reason for Selling: I would like to go down the path of building up a RB26/30 motor. Motor has been removed from vehicle and now taking up space in my garage.
Price and Payment Conditions:
RB20DET, re-built motor, mildly worked - $1000 firm
Pick-up prefered.
Info:
The RB20DET, re-built motor, had the following work done to it, as stated below:
RB20DET Block
MACHINE & SERVICE CYLINDER HEAD
3MM STEAL HEAD GASKET FITTED
GENUINE NISSAN ENGINE FULL CYLINDER HEAD GASKET KIT FITTED
VALVE LIFTERS REPLACED
GENUINE NISSAN MANIFOLD GASKET FITTED
GENUINE NISSAN OIL SEAL FITTED
GENUINE NISSAN ROCKER COVER GASKETS FITTED
GENUINE KEY WAY CRANK SHAFT FITTED
GENUINE NISSAN TIMING BELT FITTED
GENUINE NISSAN CRANK SEAL FITTED
RECONDITIONED FRONT CRANK SHAFT PULLEY FITTED
GENUINE NISSAN THERMOSTAT FITTED
Motor setup, fitted with the following parts (please take note these bolt-on parts are not provided in the sale) Garrett 3540 Turbo, 3" exhaust system, front mount intercooler, Microtech LT10 ECU tuned on 19psi made 238.3kws (Can provide the print-out of the dyno sheet for proof).
Receipts for the re-build can be provided aswell.
Please note:
The motor is sold as is pictured. The turbo and oil lines (for the turbo) are not provided with the motor.
Pictures:
https://www.sau.com.au/forums/topic/332447-rb20det-re-built-motor/
Price dropped to $600 firm.
bump!
hi could you please text me on this number 0405232544 when you get this, just say something about the engine in the text, i am interested
hey mate just wondering if you would consider posting at my cost to 3136? i could organise it
PM sent
what does it compression test at ?? people will always be interested in this !!
I will take this in consideration, will post the details shortly
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
