Originally posted by inark
Mine cost me under 2k and that includes a 19" Flat and Ti4200... :D
If ur in Melbourne and wanna upgrade... buy ur parts from MSY.
where and what is msy?
is the Ti4200 the card that retails for $800 odd
and i have to say that the AMD kicks ass to the P4 for games!:shake:
https://www.sau.com.au/forums/topic/3325-home-systems/page/2/#findComment-61493
dont make me post all the reviews and comparisons by most game/hardware sites :D
nah the Ti4200 i got retails for about 330 for the 64MB card (leadtek price) for the XFX card which is the one i got its about 295.... clocks very easily to 4400 speeds and with some extra cooling u can go to 4600 speeds... those cards cost 800
MSY is in Malvern....
***edit
Here INASNT -
http://www.hardwarezone.com/articles/artic...&aid=481&page=1
read it.
https://www.sau.com.au/forums/topic/3325-home-systems/page/2/#findComment-61502
Back again.. :)
Just a little info on the Sparkle card that I looked in to and bought.
It clocks with mem cooling to ~580mem and 330core i think it was.
You do need a new heatsink on the core but, the core doesn't make a huge difference to speed it is mainly the mem so 300core with std heatsink is pretty safe.
Also the card is an exact copy of Nivida's reference board.
The 128MB Sparkle Ti4200 was when I bought it $350.
It uses the Samsung 4ns ram which is good quality ram.
Good value.
Also again.. Don't get the 64mb version it will run slow with the new games that require 128mb of onboard vid ram.
Other wise it will use the AGP aperture that is obviously slow(er).
Just like trying to run Mohaa on a 32mb gf compared to a 64mb GF.
https://www.sau.com.au/forums/topic/3325-home-systems/page/2/#findComment-67686
P4 1.3Ghz
384MB 800MHz RDRAM
60GB Primary HDD
20GB secondary
8x Iomega CDRW (shut up, its old, but bloody reliable) :)
Hercules Game Theatre XP Sound card
21" Silicon Graphics Monitor (cost me 300 bucks, bargain or what?)
Creative GeForce2 GTS 32MB (soon to be replaced by a 128MB Radeon 9000)
MS Intellimouse Explorer
Panasonic 52x CD-Rom
Panasonic floppy drive
MS Sidewinder force-feedback Wheel and pedals
full surround sound speaker setup
3Com 10/100 NIC
WinXP Pro
PC #2
P3 800MHz
256MB SDRam
10GB HDD
Creative Labs DVD drive (6x) with DXR3 hardware decoder (TV out plugged into TV, audio out plugged into 5.1 surround sound system)
Built in VGA and sound (only use the sound from the decoder card though)
15" monitor (5 years old and still going strong)
Win98SE
Thats about it for this one, I just use it to play movies which it does very well.
PC #3
P3 450MHz
256MB
16GB HDD
DLink 10/100 Nic (connected to cable modem)
3Com 10/100 NIC (connected to switch)
Creative Labs TNT2 video card
12x CDRom
Modded case (painted it really cool, cut hole on side, neon light inside) (pics here )
no soundcard
no monitor
Win2k Server (this is my net server. Runs as a firewall/router as well as storing some of my files that I really should burn to cd...)
https://www.sau.com.au/forums/topic/3325-home-systems/page/2/#findComment-71656
hehehe my system owns you all...
PII 350
ASUS Motherboard (Supports SDRAM, Onboard Raid n shit)
ASUS 3400 Deluxe vdieo card (S Video + Composite Video In & Out)
SB Live
SB16 (yes 2 sound cards)
80GIG HDD
6 Gig HDD
3 Gig HDD
24x CD Writer
36x CD Reader
Infrared port
56 K Modem
Dirty MS mouse
Dirty Acer Keyboard
Canon IXUS V Digital Camera
17" Monitor
Runs Win2K
Does all my graphic design work.
Don't get me started on the SGI machine with the 22" Sony Flatscreen monitor + 4 Sony 6" peripheral TFT screens (used to put toolbars, file browser, photo catalogue, other images onrespectively) I used to have at my old job :)
Yeah I should get a new PC, but this one does the job, and I'm savin up.
https://www.sau.com.au/forums/topic/3325-home-systems/page/2/#findComment-71784
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
