I'm a bit rough on the troops at times . irreverent , irascible , acerbic , dirty old man with out remorse . I do have my good side . I really do teach what I learn and try to have some humor about it . Problem is I also have no problem calling an inept time waster just that , a waste of time . Guess I'll have to work on that .
I have nearly 30 years experience working on all common makes of motorcycle and and somewhat less experience working on those I can't spell . I honestly don't have a brand preference and believe that anything less than that you ride being more important than what you ride is a posture for a--hats , imbeciles and docile media led lemmings of the American public .
I digress , as per usual . If I reach the edges of your tolerance please inform me , publicly if necessary . I'm far beyond the age where a bruised ego means anything more than your using my transgression to show the rank and file what is and isn't allowed as well as keep my arrogant self out of trouble long enough to be of some assistance .
Now if anyone has read this far could you please let waxer52 know he has and apology of sorts and a reply/link in his crank thread thread
I looked around and found some things of interest but doubt I'll be around much . I'll just say thanks to all of you that pack waxwe52's PM box :thanks:
WTF are you on about? Perhaps start from the start instead of mid-essay...
Last I checked You still read and write something akin to English in Australia .
I get the whole 10 posts before you can PM (spam) someone but do you rely want to have some crazy Yank around for any more posts than it takes to deliver the message and be gone ?
All someone had to do was pass the message .
~kop
Edited by kopcicle
~kop
Last I checked being American doesn't excuse you from making sense...or does it? How about using your 10 posts to write something cohesive. Even some random numbers would make more sense.
Can't pass you a message when you don't link it correctly...
So a member here , waxer52 posts extensive pics of two stroke engine carnage at another forum Piston Bore Damage . I didn't spot the post until a month later and commented in that thread but thought if no one had answered in a month he might have given up on us . We are to all forms of motorcycles , notably kawasaki's but others also what all of you are to Skylines . Enthusiasts . I was just attempting to pass on some lessons that were learned the hard way . I'm a little unusual in that I go the extra little bit to help someone . Not many would chase down the posts of a new member all over the web to get the information to them . I would . I'm about as far from a troll as you can get . I actually get the whole idea of collective knowledge and experience benefiting all that care to , well , care . the corrected link crank thread thread
the guy is genuinely trying to help waxer52... agreed, his description of goings on didnt make too much sense.
but he has tracked waxer52 accross forums looking for him to let him know he replied to a post on a motorcycle forum which presumably waxer52 doesnt visit often.
thumbs up yankee, thats dedication :rofl:
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
