Hi Riceline, in your picture you cut off the 4th connection, the one that goes to the PCV valve on the plenum.  It is on the cam cover juts down from the blue one in your picture.
If you open up the angle of the photo a bit so we can see the inlet plenum, then I can draw on your picture the choices you have for plumbing up a catch can.  Yes that's right you have CHOICES, there is not a wrong and a right. :P
Id be extremely interested in seeing this too, I assume itd be along the same lines for a GTR? Looking at putting one on, what would be the best way of doing it?
  • Replies 64
Exactly the same for a RB26DETT, or an RB20DET or an RB25DET or an RB31DET (in my case). But keep in mind there is no "best way", you choose whichever suites your requirements.
I call the choices :cheers: ;
1. 100% plumb back
2. 50% plumb back
3. Zero% plumb back
Anyway, more when the picture is up. :wave:
So what options do/dont u have if your catch can isnt vented?
I have a trust can which is basically hollow but looks cool.. not vented.. u know the one.
Whats the best option for say; 230rwkw or less, running either standard or hiflowed turbo, big intercooler, on 12psi constantly?
I think this suits alot of people...
Is this right?
Let's try this one, it's the open to atmosphere catch can;
The idea is to only have one connection from the cam covers as they are joined by the standard pipe. The PCV valve and the connection to the inlet before the turbo are blocked off. You can have a return (drain) to the sump form the catch can if you like. Don't T it into the turbo oil return as it is under a bit of pressure and the oil can run up into the catch can.
The other 2 options follow in separate posts. :D
SK doing it that way wont cause any probs to idling?Don't laugh but is the blow-by metered by the air-flow meter,coz after all it is air that has been metered.What i'm trying to get at but slowly :D is blow-by the same as air from a bov that is being vented to the atmoshere?
SK doing it that way wont cause any probs to idling?Don't laugh but is the blow-by metered by the air-flow meter,coz after all it is air that has been metered.What i'm trying to get at but slowly :) is blow-by the same as air from a bov that is being vented to the atmoshere?
Good question R31 POWER, but if your engine has enough blow by to cause idling problems, then it is not the blow by that you should be worried about. :spew:
Sorry for the delay, virus on the laptop :type:
This one I call the 50% plumb back, because half of the time (no boost times) the air from the catch can is being sucked into the inlet manifold via the PCV valve;
It is not my favourite, because you can still get a bit of oily air into the engine, but since it doesn't go in under boost (the PCV valve is closed then) detonation isn't much of an issue. At least you don't get any oil into the intercooler and its pipework.
The last is 100% plumb back, all of the air goes back into the engine. Some goes via the PCV valve, at times of no boost. When there is boost, it goes back via the inlet system, through the turbo, the intercooler and its pipework. :uh-huh:
The idea is the stainless steel wool, helped by the lower velocity in the catch can, catches the oil and removes it from the air before it goes back into the engine. This is the environmentalists favourite :alien: and is the easiest to get engineered.
SK,
How would you plumb it, if emissions were not an issue, as in a 100% race engine. Metohd 1, 2 or 3 ?
On the race cars we run open to atmosphere. We do run 2 pipes to the catch can and remove the joiner (standard) pipe between the cam covers. It's not really necessary on a road or combo car though, the one pipe does the job OK.
Hope that helps :)
So, would it be acceptable to plumb the PCV line to the catch tank, and leave the joiner as is, with the tank vented to atmosphere ?
As long as you block off the unused plumbing and fittings. I gotta ask why though? :confused:
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
