Hey guys,
First of all I would like to say hello to everyone in the community. I just signed up having purchased an r33 skyline this week. I must say that I have read all your forums to death and feel I already know most of you quite well.
Just thought I'd get my face out there a bit with you blokes cause I'm sure I'll be seeing you all around the block. My first mission starts tomorrow when I pick up my new R33 from Palm Beach in Queensland. I will be flying up there in the morning and driving solidly back down.
Needless to say I'l be making videos and taking photos along the way with my very sexy and cool housemate.
I may join you on this dinner, but most importantly I look very much so forward to talking to you in the near future, dicussing times, good and bad.
I assume I'd know some of you from out and about as well. Been on a few ACC cruises and grew up in the hills, spending most my time on the roads.
You seem like a great bunch and the amount I have learnt already from you all is astounding.
Cheers
https://www.sau.com.au/forums/topic/333669-intro/
Welcome Peter, always good to get some new faces around here. Actually use to have a 4 door R33 myself :thumbsup:
RB25DET FTW!!! Unforfunately it might have to go through regency... Which of course means a ton of steel wool and some detective work with the turbo timer!
Needing some work done to the front on the new bad boy as well... The front wheel is about an inch or 2 off where it should be. Sounds like a new shock. They wont wheel balance till its fixed... which of course means a bumpy ride from Queensland
https://www.sau.com.au/forums/topic/333669-intro/#findComment-5408939
Welcome to the forums Pete. We do however have a 'into' thread that should have been used and not a new thread created. It is here (click). Then a link to that thread in the wasteland of the dinner thread would have been sufficient.
In my opinion I definitely wouldn't be driving a car from Qld to SA if there is any issue whatsoever with the wheel/shock/whatever. Especially if the wheel needs a balance of the car needs an alignment. At 100km+ problems get amplified many times and we would hate for you to leave the Skyline community so quickly on your way home. Just something to think about.
https://www.sau.com.au/forums/topic/333669-intro/#findComment-5408956
Thanks for your consideration mate, But I'm in a situation now where I have to get it back. Car has been purchased, plus limited cash and time has not allowed me a way to fix it. If you saw how much trouble my maxima is in at the moment (my current daily), then you would see the urgency for this skyline. The skyline is still very drivable, and Il be going very easy on the roads. I really appreciate the thought though, my family and such have said similar, but there is just no time. I need it back this weekend for work. I will be doing the shock on the monday night I imagine, followed by an alignment on the Tuesday morning. Will let you know how all goes anyway
https://www.sau.com.au/forums/topic/333669-intro/#findComment-5408974
Hmmm... the owner happens to be my brother in law. He has promised to pay the dif if its anything over $300. HOWEVER! That said. He failed to mention the car was unrego'd until after I purchased it, and made pay the rego ($470 in Queensland for the minimum). Bit lame ey?
https://www.sau.com.au/forums/topic/333669-intro/#findComment-5409012
hrm how long is the minimum amount of registration in QLD?
for 3 months here its around $210 or something... might have been worth just getting a 3 day pass and then rego in SA - unless its a 6 month + rego
-D
https://www.sau.com.au/forums/topic/333669-intro/#findComment-5409034
I have transfered into my name there. Queensland only do 6 months. Cant do 3... :thumbsup: Bummer, but I'll just refund it anyway so thats ok. Question is, because the car is over 15 years old will I need to go through regency? Or just get the VIN checked. Turbo timer and such on it you see, dont want to get a defect.
https://www.sau.com.au/forums/topic/333669-intro/#findComment-5409046
then you only need to fill in a change of address form
i would personally keep it registered doesn't matter where a car is registered its legal to drive anywhere in australia
Hmm... read somewhere you can only drive it for 3 months like that. I dont want queensland number plates anyway... Proud to be south aussie :thumbsup:
https://www.sau.com.au/forums/topic/333669-intro/#findComment-5409058
    • After throttle body? I’ve heard that you should not do that. Even if you look at the diagrams they show you that you should take boost from turbo.
    • What do you mean with ”hot side”?  From what I’ve heard is that you should take it as close to the turbo as possible?
    • Like on the intercooler pipe between turbo and intercooler?  Still weird why they don’t put an output on the turbo since you will need one. There is one for the RPM of the turbo..  are they doing this because they want you to take the boost reference from somewhere else except the turbo?
    • That wouldn’t work especially well? 🤔
    • Hi all, I’ve just finished fitting the timing belt on my RB25, following the standard procedure: rotate the crank twice, release the tensioner, then tighten it down. The belt feels tight, and you can see that clearly in the picture below I’ve heard some people say it’s actually better for the belt to be slightly loose rather than too tight, as excessive tension can lead to snapping. So that’s in the back of my mind. What I’m seeing is this:  • At idle, the belt looks fine.  • But when cranking and especially when revving (around 3–4,000 RPM), there’s a momentary flap/flex or flicker in the belt, which I’ve tried to capture in the video. So my question is — based on what you see, is this slight belt movement something you’d consider normal, or am I just being OCD? Could this amount of movement cause sync issues? Or is it just a harmless bit of flex under load?   from what I know belt flap and flex is expected when crank spins up and pull cam with it Would appreciate any thoughts or similar experiences.     IMG_7656.mov IMG_7657.mov
