Located in SE MELB
For sale: 4 sets of 20pcs D1 Nuts, - long version no lock nuts
Blue or Black
1.5mm or 1.25mm
Price and price conditions: $75/set
Pictures:
For sale: RAIZIN VS-E unti with 5 groundings GOTTA GO!!
http://pivotjp.com/imitation/imitation-raizin-e.html <-------- click to see the difference!!
Price and price conditions: $110 ---> $100 .RRP $160 + shipping
Pictures:
Edited by m3ntal_l2
https://www.sau.com.au/forums/topic/333740-vic-d1-racing-nuts-raizin-pivot/
Hi,
What size are the outside nut diameter?
I'd like to know if it's 19mm so I can fit inside my AVS Model T5 (21mm socket won't fit).
If it's 19mm, I'd like black set.
Cheers
Grant
Hey dude, about the pivot voltage stabilizer. It works good on my car, no more whining sound from speakers when revving, Cluster light is brighter, headlight and other exterior lights is bright too. So it works for me.
Cheers
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
