as title:
1-R32 GTR gearbox with transfer case traveled probably 130,000kms gears seemed good but could probably do with new syncros, crunched a little at high revs 3rd to 4th. $500 ono
also 1 cat back exhaust not sure on brand or size at the moment did run on the car making 430kw wasn't drowny or that loud either $200 ono
parts located in Vic west suburbs
P.S Att mods: i did post this yesterday but seems that it disappeared if mods find it please delete this one cheers.
to be honest i have no idea, would have to assume it was an 89 though??
ive attached a pic if ppl wondering push or pull. im not sure so if yours looks like this then it will work. sorry
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
