Hi all
Just wondering what people have done about installing a catch-can in an r32 GTR with an rb30dett. I had an autech-style one (big tubular one) sitting above the cam covers but with the rb30 in there, there is no chance of getting the bonnet shut.
I am on a low-boost run-in tune at the moment so hooked up the factory style setup but would need to sort something out before final tune.
Any recommendations about what you've used/bought/made yourself, and in particular photos, greatly appreciated.
Cheers
Andrew
  • Replies 51
Posted Images
Grab yourself a set of Mines cam cover baffles. These will greatly reduce the amount of oil vapour coming out. Then you can keep the standard setup.
I have these, they did nothing....sorry to say. I run the Pro Vent catch can with the return into the dipstick tube. Its a real catch can not just a shiny empty can.
Pro Vent 200
They are cheapest off ebay
Pro Vent 200
looks good
do you have any pictures of it installed?
Pro Vent 200
You must have a fair bit of blow by then.
Myself and a friend of mine put a set of Mines baffles in both of our engines (both making over 400rwkw) and vitually stopped any oil vapor getting to the catch can.
i run a border catch can which i got from rhd japan then modified as directed by rob @ rips.
the correct way to run a catch can is to have both cam covers run individual lines to the top of a catch can which should have a filter, then run 2 seperate lines from the catch can (1 at bottom & another at mid point) back to the side of the sump so that it runs back into the sump
Pictures tell a thousand words ;)
The two lines back to the sump.. intake side? above oil level or below? seperate fittings on sump?
Thats what I though, leak down is less than 2% however. I think my issue was more an excess of oil in the head and-or to much Vac return. I am running the 1st breather from the high side of the drivers cam cover now instead of the low side on the passenger cam cover. Same as the Mines R34- dual catch cans (in series) Still returning to the intake. The PCV return has been blocked off. Will post up a pic later if you like.
Closed loop system to keep it 'more legal'
Edited by BoostdR
sorry bubba - 2 lines run from the side of the catch can back to 2 fittings in the side of the sump, at the highest pt of the sump
Hey Marko how's things?
2 lines back to the sump? that's a lot of drainback. almost sounds like its one line from the sump to let it breath (the one that goes in mid point) and the other is a return line.
that is exactly right mark :blink:
That's how I understood it too..
My head already has the vent on the back so I will be going 3 hoses to the top of the can (2 cam covers and the vent from the back of the head) then I'll do it how Markos is, vent sump to midway up the can and drain from the bottom.
that would work
That looks just like the NISMO oil air kit which plumbs into the rear turbo oil line and looks pretty neat aswel I might add
The nismo Doesn't work on an RB30 block...with the turbo bolt-on return anyway. Def the go on a 26
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
