Hi all
Just wondering what people have done about installing a catch-can in an r32 GTR with an rb30dett. I had an autech-style one (big tubular one) sitting above the cam covers but with the rb30 in there, there is no chance of getting the bonnet shut.
I am on a low-boost run-in tune at the moment so hooked up the factory style setup but would need to sort something out before final tune.
Any recommendations about what you've used/bought/made yourself, and in particular photos, greatly appreciated.
Cheers
Andrew
  • Replies 51
Posted Images
Grab yourself a set of Mines cam cover baffles. These will greatly reduce the amount of oil vapour coming out. Then you can keep the standard setup.
I have these, they did nothing....sorry to say. I run the Pro Vent catch can with the return into the dipstick tube. Its a real catch can not just a shiny empty can.
Pro Vent 200
They are cheapest off ebay
Pro Vent 200
looks good
do you have any pictures of it installed?
Pro Vent 200
You must have a fair bit of blow by then.
Myself and a friend of mine put a set of Mines baffles in both of our engines (both making over 400rwkw) and vitually stopped any oil vapor getting to the catch can.
i run a border catch can which i got from rhd japan then modified as directed by rob @ rips.
the correct way to run a catch can is to have both cam covers run individual lines to the top of a catch can which should have a filter, then run 2 seperate lines from the catch can (1 at bottom & another at mid point) back to the side of the sump so that it runs back into the sump
Pictures tell a thousand words ;)
The two lines back to the sump.. intake side? above oil level or below? seperate fittings on sump?
Thats what I though, leak down is less than 2% however. I think my issue was more an excess of oil in the head and-or to much Vac return. I am running the 1st breather from the high side of the drivers cam cover now instead of the low side on the passenger cam cover. Same as the Mines R34- dual catch cans (in series) Still returning to the intake. The PCV return has been blocked off. Will post up a pic later if you like.
Closed loop system to keep it 'more legal'
Edited by BoostdR
sorry bubba - 2 lines run from the side of the catch can back to 2 fittings in the side of the sump, at the highest pt of the sump
Hey Marko how's things?
2 lines back to the sump? that's a lot of drainback. almost sounds like its one line from the sump to let it breath (the one that goes in mid point) and the other is a return line.
that is exactly right mark :blink:
That's how I understood it too..
My head already has the vent on the back so I will be going 3 hoses to the top of the can (2 cam covers and the vent from the back of the head) then I'll do it how Markos is, vent sump to midway up the can and drain from the bottom.
that would work
That looks just like the NISMO oil air kit which plumbs into the rear turbo oil line and looks pretty neat aswel I might add
The nismo Doesn't work on an RB30 block...with the turbo bolt-on return anyway. Def the go on a 26
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
