yeah fathers day...
not sure if ill be able to be there all day as its my first fathers day and the missus has something planned but ill
see what i can do.
lets hope it goes well and there is plenty more of them!
  • 4 weeks later...
Some good Nissans out on the day at this meet
One of our Willall Racing customers - Gav - ran 11.3 in his Exhaust + Tune R35 GTR (you might have seen it the red one at the SAU Dyno day)
Our Willall Racing development EVO X SST ran 11.9
There was an R32 GTR running 12.1
A great day and well worth it :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
