And WTF are they doing. 39.9% is not full, so it is rather irresponsible to lighten restrictions going into spring/summer...
The north south pipeline was switch on this year, so that's probably part of the decision
Edit: Ahhh yeah... what Greg said ^^^
The only thing stopping me from washing my car now is time :D Too freaken busy :O
You have listed a Supra / 300ZX / MR2, which are the cars you "did" have, you would be busy washing 3 cars on your own.
Yeah, I need to change that :D Just refer to my sig for my car list.
You can now wash your car at home using a bucket or a high pressure cleaning device
- You cannot use a hose to wash your car
- You can of course use rainwater as you could under all stages of restrictions
This change has been made possible through a combination of factors:
- Melburnians commitment to water conservation the community has saved an additional 34 billion litres since the start of the voluntary Target 155 campaign. Melburnians have used just under 150 litres per person since the target 155 campaign commenced, a tremendous result.
- New sources of water are now on line and these add a new level of security and include the Tarago Reservoir and the North South Pipeline
- We have had much better rains. We had enough rain in Autumn to thoroughly wet the catchments and with the good winter rains storages are rising at over 1% per week. Currently our water storages are ~12% higher than the same time last year which equates to about six months consumption.
- Work on the new Desalination Plant at Wonthaggi is progressing very well, with completion still on track for late 2011. The desal plan will add another 150 Billion litres per annum which is about 42% of current annual water usage
I think if i hooked up my high preasure hose people walking the street would give me dirty looks just like when i washed my dirt bikes with it.. there like WTF ARE YOU DOING?!?! SAVE THE WHALES
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
