sitting on 306hp atm with r23 w/ rb25, apexi 300 or 400hp turbo (not sure which 1)n a pod, greddy radiator, hks fmic, oil cooler, 3" zorst w/ 2 hi flo mufflers n no cat, Twin Plate brass button Clutch,
Splitfire Coilpacks, shimmed diff, and i was told she had a walbro fpump havn looked at it yet tho
running 1.2bar with blitz Dual Stage Boost Controller and Turbo Timer
car has flashed over ECU with an Omoni Tune with no restrictors
my goal is 500hp so wats next to get there ?
thanks simon :(
https://www.sau.com.au/forums/topic/334040-help-me-get-to-500hp-xd/
if omoni is a jap ecu then get a new ecu quicksmart, jap ecu's are not the best for aussie fuels and conditions.
500hp is a big goal, you will kill your engine if it has stock internals,
read through the turbo results section for RB25 to decide which turbo is right for your driving use and power goal,
will need better fuel pumps, injectors etc.
will be a T4 highmount turbo so new exh manifold, dump pipe down to the cat to match your existing exh.
new intake pipe from the pod to the turbo, new cooler piping from the highmount turbo, new water and oil lines and oil return for the turbo,
new ecu and tune,
This really is the point where we are meant to say search :(.
Yet, you will need to change just about all your current mods bar your clutch. 500HP at the wheels will warrant a set of slugs so, if your not interested in spending 10K minimum to get there, dont bother.
If you shot for 400 instead you could go injectors/ecu/turbo which could cost you less than 5K if your smart about it.
Please see:
http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
