hey man just had search but i couldnt reli find what exactly i was looking for...i just need a quick answer...is it a big job to put a rb30de bottom end onto a rb25de? n will help me run higher boost more safely?
plz plz plz
The correct CR will help you run higher boost safely. so while u got the RB30 block apart, replace the pistons for lower CR, just grab a set of VLT pistons, they will be fine. if you read thru the rb30 conversions in the "forced induction performance" section, you will notice it isnt sucha big job.
if anyone is planning to do this, i have the stock R33 intercooler and piping for sale atm, for $80 ono. just pm me, its all in very good condition btw.
Don't be fooled gents. its not only the compression factor, but the piston itself, the N/a pistons are not Hyperputectic. therefore, even with low boost pressures, after a while you will melt a piston.
By all means, do this upgrade! turbo is 100% better effecient power, than most other mods. But do plan to change your pistons over in the near future.
Not really, my car ran fine for a over 50,000kms and as far as I know is still running fine without ever being cracked open to change pistons.
Melting pistons is from a poor tune, you can do it with any engine
the cast pistons will not tolerate the higher combustion temperatures associated with boost.
of course a good tune will help keep detonation to a minimum and the correct supporting modifications will ensure oil temps and water temps are kept low, but eventually the pistons will give up the ghost.
an example is my good friend who has a famous AE86 drift car here on the gold coast.
He had a stock 4AGE bluetop (bigport) bottom end which has the smallest rods, crank and gudgeon pins of all the 4AGE's and it took 6 months of punishment from a HKS GT2510 at 13 PSI pushing 150 kw at the wheels out of 1600cc.
It had a great tune from Adam from JEM and had all the supporting mods like a alloy radiator, great intercooler, big fuel system and oil cooler. The water temps never got above 82 and the oil never about 90 - 95. Eventually, the pistons gave up. But it goes to show that a motor can be pushed to nearly triple its factory power and still last for a while given that the correct supporting mods and great tune are applied.
Side note: I have read that the turbo RB30 pistons with the twin cam head will result in a 7:1 CR. too low
hey i just though i would go back a little bit and add something in, in relation to drilling the oil return line into the block a way of getting around this would be to buy an oil cooler and run the oil lines from the oil filter to the oil cooler to the turbo out the turbo then into the engine and around agian, this way you would have the best oil going to the turbo and you wouldnt have to worry about drilling holes in the block, and as a bonus it would be even easier to return to stock if needed
  • Like 1
13psi in a 10:1 is asking for trouble that would have contributed to the death of that engine...I owned a blue-top as well and managed to melt the piston without a turbo.
under 8psi with stock pistons will see a reliable engine that won't need forgies and will live a long prosperous life.
ive got vacuum hose running straight from the compressor nipple to the wastegate actuator and its natural boost is .8 bar.
i do have a bleed valve in the line but its completely shut. i might delete this as it may still be causing a boost increase.
If you've got an RB20 turbo that's normal though, the actuator I put on my highflow from an RB20 was 13psi straight on the actuator, no bleed valve.
Grab one from a series 1 R33, it should be nice and tired and give about 6psi
Absolute bullshit, my series 1 25de had the oil return just above the sump blanked off which simply unscrewed to fit my return line fitting. The same as the water return and oil feed, the only thing I had to source was a water feed which I t-pieced from a heater hose. Piss the rb20 crap off, accept a 25det stock turbo as a minimum.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
