That's nice! I'm not a huge fan of the green colour on skylines, but I don't mind that.
Can't say I've seen it though...I have seen a green Skyline (can't remember if it was a 33 or 34 now) in South Bank Brisbane, but I don't think it was that one.
Yeah that's a big saving definitely! JustJap have the PowerFC's listed about 2Gz now!
its ford headligght i think from xr8 or xt
had to sell it tho got defected to many to get clear. lol oh well. he would of gave it to me =[
anyways dont wanna change topic so if anyone reading im in need of all the bit to go turbo,
thanks
I've got a Turbosmart Single Stage Boost Controller if you want to use that..I want to go EBC due to the way the boost fluctuates on the R34 N/A.
How much are you looking to spend? That will dictate how much to spend. For example whether you want to use a factory manifold and factory R33/R34 turbo, or go for an aftermarket exhaust manifold and aftermarket turbo.
Do a search in the for sale and post up in the Wanted to Buy, should find some good bits there.
If you want a parts list I'm sure a few of us can put up a list of the parts we used to get you started.
I used a mix of aftermarket and factory parts. Pretty much everything was new/used aftermarket bits except for the injectors which I used GTT injectors, exhaust manifold was a factory item, and a R33 series 2 Turbo though I wish I held out till I found a good R34 one
mate has offered to sell me a complete factory series II turbo setup ( turbo, ECU, manifold, injectors, heatshield ) to bolt striaght onto my series 1 R33 NA. for $350. no shaft play etc...
couple of things i thought might be worht checking first tho, the NA fuel pump im guessing mightnt be enough, so will i need to get a GTSt/GTR one? or will it suffice for the short term. otherwise obviously it may run TOO lean. also, any extra lines i might need to run? (water, oil)
Not bad for $350!! Yes change the fuel pump.
GTSt or GTR like you said, or get a Walbro pump. Given the age I decided just to get a new Walbro GSS342 ( I think this is the same model for the R33?) Best to be safe and upgrade it from the start...plus saves retuning again later.
If you're running the stock turbo n all, you could probably go with a JJR Front/Dump Pipe from Just Jap...$200 does the job well, I used one myself. Hi Power Racing used different gaskets than what was supplied though.
What are you going to do in terms of intake cooling? Vic has the one intake mod rule yes? I would sooner try and get a factory airbox with a hi-flowpanel and run a FMIC on a high compression turbo setup.
iirc the R33 has the oil feed blanked off with a blanking bolt? With the R34 custom lines had to be made up, and there were a variety of ways it could have been done.
Edited by N-DAWG
it should, the loom is the same. and ndawg, got the factory dump pipe aswell so its all good.
sourcing a factory SMIC too, yes vic rules are actually quite restrictive, cant even have a turbo. SO, were doing a stealth job on it :domokun: hopefully will turn out alright, heatshields and the like cover it up farely well.
have factory airbox too btw
I see...in that case try to get the thicker core R34 SMIC to keep temps low. You realise that there are insurance issues as well with illegally driving a turbo car, yes?
Yeah use the airbox... the high compression starts making boost at 2,000 revs, and with a pod it is blatantly obvious that there's a turbo with the induction sound it makes.
well its 5am, got it all done an hour ago. couple of issues atm;
manifold gasket needs to be replaced (slight leek)
the turbo ECU i have doesnt prime the fuel pump (go figure, the mounts dont even match)
still need to get hold of a SMIC and turbo airbox by the looks (running an elbow from the plenum direct to turbo)
running a bit rich and obviously not to its full potential because of the stock ECU ( NA one )
need to move the atmospheric filter to a less obvious spot (mini pod filter)
was a fairly simple task, minus things like having to make custom hosing etc, and getting the injectors out (FUUUCK) sprayed most of the piping in engine enamel black too, so looks really neat. turbo is well hidden away.
all in all it runs fairly smoothly though apart from those issues, will post up pics tommorow of the current setup.
i am aware of the insurance issues, and many others...but yeah...have all the bits to convert it back to stock form if need be
ED: had to run the oil drain tapped into the VCT lines as there was none other tapped into the block. tapped into the heater hose for the water drain/feed (not sure as its too late and i want bed now!)
basically, when you turn your ignition to the second accesories point (where all the dash lights come on) but not start, you should hear the fuel pump (located in the boot next to and under the battery) prime..makes a high pitched sort of noise. and we got nothing with the turbo ECU. my theory is either the ECU was dodgy, or its not meant to for NA pump, OR its off a series 2 and that for some reason they have a different loom... any ideas?
we started at about 6.30 the night before, so it took about 7.5 hours in total...not bad
haha wherebouts your from calvin?
I don't see any logical reason why it wouldn't prime... my N/A pump primed, and the GSS342 Walbro pump primes also. Something doesn't sound right...
in the process of tracking down another ECU, and airbox/piping/cooler. has been running well today tho, minus the water feed rupturing :D all good tho, atleast it wasnt in a flamin mongrel of a spot to get at. have noticed it has a tendancy to stall a bit at low revs but im guessing thats cos the ECU isnt a turbo one.
heres some pics of the setup as of today :(
if the copper that pulls you over knows their shiet, they will look for the intake pipe and should know that it runs directly off the TB straight to the airbox (as all NA's do it). if you get a noob copper who doesn't know anything then you're lucky.
nice clean setup tho :)
ran out of coolant O_O turns out whoever did it last night (or this morning) had no idea how to bleed it in. all good now with a nice fill up, runs a bit better too :)
doris right, thats why i want to get the factory airbox/piping/cooler so its even less obvious
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
