Hi All,
Unfortunatelly I need to sell my project, to many toys, not enough time or money to go around.
Car is registered and I drive it regularly.
Engine, Intake and Exhaust:
RB25/30 DET
Custom cams
GTR injectors
Custom Greddy style, port matched inlet manifold
Adjustable cam gears
RB20 exhaust manifold
T3/T4 turbo/ V-band outlet.
Chipped RB20 computer
Huge R34 GTR intercooler
Two exhausts one new from liverpool exhausts with two mufflers and is quiet. One with cat and rear muffler only and loud. Can be swapped at front of cat.
Z32 AFM, relocated.
Adjustable fuel pressure regulator.
Twin RB20DET recirc valves, with custom piping.
Twin oil catch cans.
All custom intercooler piping.
RB25 Throttle body.
Mild Ported and polished cylinder head with back cut valves and de-shrouded combustion chamber valve pockets.
Cometic head gasket with new head bolts used.
Liquid forged RB30 pistons.
Low compression ratio, about 8 to 1
500hp Walbro fuel pump.
Body:
Fresh paint done by Panel Pit in Condell park, NSW. Colour is a fairly new commodore colour called "evoke"
R32 GTR Rear spoiler
Jun S13 Flares
Diezel wheels, 17x10 with good tyres and wide offset.
Cut out front and rear gaurds under flares, rears have been rewelded and sealed.
Front strut brace.
Battery relocated to boot.
New tints, all except front
GTR style fibreglass bumper.
Custom front lower undertray panels.
This car is wider that a 32 GTR with the flares on it and the sedan has lower roof line. If you think 32 GTR's look fat you will like this.
Interior:
Tidy Std interior with good vents and dash.
Touch screen CD/DVD player
New speakers front and rear
Four channel boot mounted amp
Running gear:
RB20 Gearbox
Heavy duty fibre clutch
RB20 LSD diff
Nismo suspension
GTR rear sway bar.
Car runs very well and I find it quite economical for how well it goes. I've never dynoed it but set it up with my innovate tuning equipment on 15lbs. It has 255's on th back and has no trouble giving them a bit of a roasting.
It idles quite rough, kinda like a bridgeport rotary and keeps with the old school theme. We all know RB's go hard even with STD internals
but sometimes you just want big cams and some attention, at least with the loud exhaust fitted anyway.
The car is what I would consider a 95% finished project, I drive it regularly but it has a few normal Skyline issues. A couple of the window switchs dont work, the aircon seems to have a mind of its own, the painters stuffed the central locking and I get the occasional hicas light.
The car owes me well over 25K and thats with me doing almost all the work except the paint job. For someone who was not doing their own work 35-40K would be more like the real value of the work and parts.
Asking $19,000 or best reasonable offer.
I dont have any pics on this computer but will post some tomorrow.
PM or call for more details.
Cheers
Perrin
0415135177
Hi All,
RB25/30 DET
Custom cams
GTR injectors
Z32 AFM, relocated.
RB25 Throttle body.
Body:
Jun S13 Flares
Front strut brace.
Interior:
Running gear:
RB20 Gearbox
RB20 LSD diff
Nismo suspension
GTR rear sway bar.
Cheers
Perrin
0415135177
A couple of things I forgot to mention.
Car was originally A GTS25 non turbo.
It has been converted to five stud hubs and brakes from R32 GTST
Has a new Nismo Gear knob.
It has Nismo engine and gearbox mounts.
that is mint.how did you get the gtr spoiler to fit on so snug?i got one on my 4 door and i cant reach one of the bolts to fit a nut on it
Had to drill new holes in the boot lid, the originals are in different spots but the GTR spoiler covers them.
Also if its under the support frame inside the boot you need to cut an access hole.
Hey All,
Not having much luck with the sale, I'm prepared to split the engine from the car now if anyone wants it. I dont actually want to part the car out but will sell the engine with clutch, Gearbox and everything to
Keep it running as it is except the intercooler and the fuel pump.
If its gets sold I'l be converting the car to V8 so anthing related to the engine that suits the RB can go.
Would be excellent conversion kit for anything that can take the 3ltr.
I also have most of the bits to do an auto to manual conversion on an R32 if anyone is considering ditching their auto.
Asking 6k for the lot. I'll chuck in the gearbox conversion stuff if someone wants it.
Happy to take you for a drive if your serious.
Perrin
Hey All,
Perrin
Bump, Looks like the GFC is still going strong!! no interest in a sweet street 3ltr DET?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
