Hey i have an R32 gtst that im wrecking. any interior, exterior panels and engine parts. are available at the moment so if your interested call or txt me on 0417090965 to make an offer. Engine only has 105xxx kms. Which is very low for a 32.
- GTR side skirts and rear pods which i got off a gtr so they are plastic NOT fibreglass. $300ono.
- adjustable coilovers/ lowered suspension $500ono
- manual gearbox $500ono
- front and back seats $100 for the lot
- doors $100 ono
- door trims $30
- dash $60
- turbo timer $15
- front mount intercooler piping $100ono
- headlights $100ono
- front 1/4 panels $75ea
- scuff plates $30 for pair
- centre console $50ono
- seatbelts $20ea
- skyline floormats $30 for the set
- 3 inch catback canon muffler exhaust. (Mandrel bent) $125ono
- turbo $150ono
- manifold $200ono
- brake calipers $50ea
- ect..................i think you get the idea.
here are some photos. I have not pulled the engine appart but will do on request for parts.
if there is absolutly anything you can think of send me a txt. or even if you want to come round and pull something off the car and make an offer txt me to arrange. Car is located in Padbury.
Ey u got the rubber door trims? and also r u selling the rims?
yer mate rubber door trims for $20+postage.
the rims are different sizes so that the car sits on a tilt. I think the rears are 17;s or 18's and the fronts are 16's. $350+postage for the set.
wots your postcode and i will let you know postage.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
