Hey Ppls.
Well I just had my HKS Cam gear installed at a very reputable workshop and had it dynoed both before and after.
I decided to get dynos before and after so everyone could see exact results for your information (bloody cost me heaps too!!!)
We found virtually zero difference between standard or HKS, and have dyno results to prove it.
The car was left strapped to the rollers whilst the install took place to ensure that the results were controlled properly (moving the car on the rollers can effect results).
The techician is extremly experianced with these engines so he's not a hack.
I haven't been on a long fang to gauge full 'seat of the pants' results, but the dyno says no change.
They told me that with programmable engine management I would see more results, as I could then adjust the timing as nessecary.
Anyway, I will post up dyno charts this aftenoon to show you all.
Also, I had a run done with and without my exhaust silencer (which I will also post up) and the results are remarkable. HUGE drop in power through the whole rev range, as well as big boost drop up top.
Anyway, stay posted for pictures.
BASS OUT
https://www.sau.com.au/forums/topic/33462-just-had-cam-gear-fitted-results/
  • Replies 54
The car was run on the dyno, then fitted with the cam and retarded the timing 4 degrees, and then run again.
I don't know what the actual opening and closing point were before.
Maybe the Neo6 does not get the same results as the other RB25 DETs???
wowx2
never seen no improvement from cam gear change :P
power FC time mate :)
Well you can add me to your list then :) At least for now, it may change in the future after I tune my PowerFC.
I put in my gear and set it to 4 degrees, and the car ran noticably worse. It lost all its top end and maxed out the injectors a lot earlier. Now it could have just been that it lost its top end because the injectors were maxed out. But because the AFM wasn't maxed out, I'm thinking that it was just upsetting the timing too much.
I also tried 3 degrees with similar results, but it wasn't as bad as 4 degrees. So I put it back to 0 and that's where it is now and running pretty good.
When I get my PowerFC tuned (along with injectors and AFM upgrade) I'll get them to play around with the gear setting. If they find it works best on 0 degrees, out it goes and back goes the factory gear.
You're running no form of aftermarket management?
Isn't the idea of a camgear to run more agressive cam angle? if the stock ECU is just adjusting its own timings anyhow (which i believe it largely does this off the A/F mixtures it "sees").. that would be expected wouldn't it?
Did you reset the base timing between runs? it is pretty importand, as without doing this, there will be very little results.
If you think about it, 4 degrees is a fair bit, and if it isnt doing something major, perhaps its not being set up properly.
I had a 'reputable' tuner try and dial in my exh cam, but didnt go near a timing light, just used the first (pre dial in) timing mark - and surprise, the results were almost non existant.
If you have absolutely no idea where each cam is with respect to the crank, how do you know moving it a bit in one direction is ALWAYS going to give a certain result.
It seems to me, you need to know where you are, and where you should be, and shift it by as much as you need to get there.
The installer was the gentleman who used to set up the Gibson Motorsport Skylines which many times won the Touring car races and Bathurst, so I figure he knwos what he's doing. He's also busy setting up Targa cars.
The position of the cam in respect to the crank isn't really relevant as the cam gear lines up with four bolts for clamping and one dowel hole for positioning, so it can only go on one way and in one position. Twisting the outside pulley section in relation to the inside boss is what adjusts the timing either in advance or retard.
BASS OUT
You say that the cam with respect to the crank is not relevant ?
Well then what is the point of retarding it then ?
Of course it is relevant. The whole purpose of the cam is to open and close the valves at the right times. There are a whole lot of things that can shift the cam timing, especially stretch in the timing belt.
The only thing that I can think of is that the different cam profile on the NEO engine negates the use of a adj cam gear to adjust the cam timing....
Although it's strange that it didn't have SOME sort of effect, either gained or lost power..
I'm still running the stock ECU on mine (series 1) and you can actually see the slight buldge in power where (I presume) the cam gear comes to effect...
J
Warpspeed: I'll rephrase myself.
You know where the cam is in relation to the crank as the standard pulley is already in the zero degree position. The adjustable cam gear simply replaces that pulley identically when the setting it as zero. When you adjust the centre of the gear, you either advance or retard the timing of the cam.
Well I got a VERY noticeble increase in low and midrange torque. Mine was retarded 4 degrees. These days if i'm just staying with traffic flow it never comes out of 4th til i get below about 1200 revs....though it doesn't pull well untill it's back up to 1800
I've gone through the exhaust cam gear process twice now, old engine & new one. Both times we've found 4' retard has made ~10rwkw gain & NO loss anywhere in the rev range. We have also played around with the stock VCT inlet gear (can be adjusted from factory) but haven't found too much extra.
whatsisname:
Are you able to install an Adjustable Cam Gear on the inlet side as well, without completely removing the factory VCT gear?
As in, will I still have the VCT with the Adjustable Cam gear??
The reason I ask, is because if I can install both, then I can have light weight gears on both to reduce rotational mass and maybe advanve the inlet a little.
BASS OUT
Hmmm...... not sure if you could do an aftermarket/VCT combo mate? I don't see why you couldn't make the VCT assy bolt onto a HKS/OS Giken/Grex etc... cam gear.
As I mentioned above, the stock VCT inlet gear can be adjusted anyway. For a very minor reduction in rotational mass it's hardly worth the changing to an aftermarket gear, unless you wanted both the gears to look sexy.
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 🥲 But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
