Hey Guys
so it turns out I like GTS-Ts rather than GTRs. Had a 290rwkw GTS-T before and I dont seem to be enjoying the GTR anywhere near as much so its up for sale/swap.
The car is a 1995 R33 GTR VSPEC in deep marine blue (don't see many in this colour. even rarer than midnight purple ones)
I've probably had the car for less than 4 months, out of which it sat in the garage/workshop for a month while it was getting the mods done.
it has the following:
- HKS catback exhaust
- Power FC with hand controller
- Garret 2860 - 9 turbos
- Bilstein coilovers
with just the above mods it made 270rwkw at just 15psi (Tuned by Yavuz at Unigroup). The compliance cat is holding it back atleast 10-15 kw. with a set of injectors, AFMs and more boost this will make somewhere between 330 - 350rwkw.
I've also bought the following parts which will be fitted to the car in the next few days.
- Apexi Pods
- Metal racing cat
- Blitz BOV
Below is a video of the car at the dealership. It's exactly how it looks in the clip. I have not made any changes to the exterior.
I have also put a set of new Bridgestone RE001 245s on the car. These retail for $360 each and are awesome tyres. still have 99% tread.
Asking $23,000 for it.
I will consider swaps for a GTS-T or a GTT plus the appropriate cash adjustment my way. The car needs to be well setup (no stupidly big bodykits or enormous chrome wheels). Needs to be making atleast 270rwkw with all the supporting mods. I prefer a series 2 but will consider all GTS-Ts.
I work in the city so it only comes out when I have time on the weekend. I don't even think I've put a 1000ks on it since I bought it. Currently it has 77,000k's
The car is always garaged and is located in western Sydney.
Rego till May 2011
Will take pics on the weekend.
https://www.sau.com.au/forums/topic/335024-r33-gtr-vspec-270rwkw-blue-nsw/
  • Replies 45
Hey mate i have a S15 2001 model a few lil mods to it nothing crazy very nice to drive Very clean interior and exterior
let me know if your interested and we can meet up and discuss .. cheers
Dan 0410 855 334
Dan 0410 855 334
nah sorry mate
pretty much only after a modified GTS-T or GTT
are u still interested nick?
yes i am but the wife showed me the front door when i showed her, she knows ill spend more money again cos ive spent lots and lots befor
ill try again. !!!
Edited by WARLORD
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
