the best pod is no pod.
use the standard airbox it has been proven time and time again to offer the same performance as a pod. if you want to be sik yulleh then buy a honda :down:
^^^^BEST ADVICE^^^^
man dont listen to these guys
few of em taking the piss out of ya
though no pod is prob a good option
compared to just a pod hanging of your intake
get a k&n pod
and some sort of enclosure (as hot air goes if open to)
and then if you want get another pipe going to outside (maybe near the front bar etc) of the car for cold air
Edited by gach2
^^ so spend $400+ on a pod and an enclosure and a cold air pipe that does nothing for performance?
don't do that. I have a special set of fuzzy dice here that will pull 30% more chicks. Yours for only $420.
its just not worth getting a fine for having a pod and fmic (if you have one)
and you will lose power from the pod sucking in hot air
you can get cheap enclosures off ebay for 130 or something, in that case, you may have a small increase in power, but not noticeable, the only thing that will be noticeable is the pssssssshhhhhhhhh noise it makes that will eventually annoy the shit out of you.
+1
if the pod is just sucking hot air from the engine bay it won't help or give you more power, it can only hurt. u can either buy a pod and then spend money and time buying/making/finding a heat shield, or just put a good panel filter in, which will also make the stock bov a bit louder
Had mine for over 2 years now & that whoosh sound still doesn't annoy me :D
