70-80 isnt so bad, just whore out bgs, thats atleast 1-2 levels per night if your trying
over the weekend i mean, more xp
i have an 80 rogue and 80 mage ready to go, sorta leveling my druid in resto, but also sorta just want to wait for the new characters so i can make a shammy
My 80 shaman and druid are good to go. My warlocks is only 62, but since I don't play wow as a job, getting to 60 in 2weeks isn't too bad.
Now to play him a few nights a week and I should be 80 or close to 80 by the time Cata comes out.
Time for someone to unleash who they really are.
First off i must explain. Despite having a stupd amount of toons, 8 of them where cheap, 3 where duel box's on a RAF accounts (1 BG gave me just under 1/3 of a level at level 25, and all the way up to about 50 i was getting 6-7 BG's to a full level on rested XP for 2 toons)
Then 1 was award leveled from the RAF from 1-60, so that took a total of no more than 9 minutes to go from 1-60.
account #1
(all on barthilas horde)
Cq - 80 paly
Healzymcheals - 80 preist
Ian - 80 lock
commandq - 73 hunter
alteffour - 72 druid
ianbank - 72 warrior
qqx - 63 mage
shamwaaw - 63 shaman
Dark Iron Horde
Headstab - 71 rogue
account #2 (not played anymore)
qqz - 60 mage
shamwee - 60 shaman
i have a 60 druid on this acconut too, IDK the name of it. its been a while since i have played the account
I don't understand what you just said about "Then 1 was award leveled from the RAF from 1-60, so that took a total of no more than 9 minutes to go from 1-60".
Huh?
I have an 80 Shammy & Druid, 75 Warrior, 62 Warlock, 60 DK, 40 Mage, 16 Hunter and 8 Rogue.
LOL but i have been playing for 3years
LOL headstab, awesome name
i used to have a mage called 'Dildostaff'
blizzard made me change my name :(
so i changed it to 'sorserious' :)
im hanging out for cata so i can make a shammy! i dont want to start one untill i get to use a new character! im going goblin fo sho. i hope the name 'shamwow' is available... such an awesome name for a shammy
and syfon, when are you going to transfer ur characters to my server? :thumbsup:
ive been playin wow since before bc came out, so how many years is that? i think its about 3.5 years ive been playing, and i still suck
What server are you on Clutch? I might transfer my shaman to your server! Are you a part of a decent raiding guild as pvp bores me shitless. It's all about pve and the storyline for me!!
80 Shaman - Nismo
80 Druid - Rectum
75 Warrior - Vlaka (Greek for stupid)
62 Warlock - Devil
40 Mage - Monaro
16 Hunter - Animal
8 Rogue - Bendover
im on barthilas horde mate
im in a pve guild, its just starting out, so its slow
did you get the patch last night? the cata intro is mad, and the whole world is different
pretty awesome, still cant wait for goblins!
orgrimar is totally different
I might transfer over, I'll see what happens.
I haven't played since sunday night, or started up wow at all. I'm leaving work soon so when I get home I'll start wow and let it update.
Have an RDO from work tomorrow so will play :(
Looking to get back into WOW, anyone have an account up for sale?
Legit buyer feel free to PM me, Genuine sales only please :happy:
start a new one mate, everythings different, its worth playing from the start.
They've changed a lot now, doesn't feel as much of a timesink.
Here's my hardcore pally
http://www.wowarmory.com/character-sheet.x...p;cn=Donottouch
75 atm, so even if I'm only 78 before cata I'll be happy. Can't wait to gear it up. Missed all 3 gear curves.
Huh?
re recruit a friend system allows you to Grant a level to a player for every 2 levels the RAF newbie gained 2.
So i leveled 2 toons to 60, it gave me 60 levels to "Grant" to the original account
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
