I played my Rogue last night for a bit, and Durotar is completely different.
Has UC or Silvermoon City changed at all like Orgrimmar has??
My warlock is 63, still 2 weeks till Cata so I have time to get to at least 75 :rofl2:
locks are awesome in pvp
the game will be a lot different at 85, stuff that is decent now might be better or worse at 85, warlocks will still be pretty good
warriors will get a huge buff because of the new skills they get, also the pace of pvp will be slower, no more killing people in 1-2 seconds
tranfered my warrior and paladin to Frostmourne, only plan on doing pvp, hope to get Gladiator again
if you want a big boost you leveling and have nothing to do now you should do 25 quests in icecrown and stormpeaks ready to hand in when cata goes live, it will get you about half way to 81 in less then 5mins if u do quests that have hand in all in the same spot
Edited by driftnick13
coming out tomory i think, the nerd que is gonna be large so i might just wait till the next day...
day or 2... there i always a few weeks of bad lag....DCing...random crap, and anoyed nerds raging all thru trade chat about issues that happen every time there is an Xpac.
so yeah i'd wait a week before trying to actually play.....lol
Farrrrk yeah, Cataclysm tomorrow! EB Games at the morley galleria isn't selling it till 4pm onwards :(
At least I can go straight after work and get it :D
its not as easy as it sounds, youll have to deal with xmas crowd and then the nerd crowd for eb
picked it up for 38 bucks at jb last night, no crowd, was really quiet actually.
i started a goblin warrior last night, the starting quests for them are awesome, and the racial abilities are pretty cool to, they come in handy
Edited by Clutch
Honestly i am not sure =[
Something about their overall appearance wasnt as... fearsome? as i had hoped.
Or at least being a hunter anyway. I think they will look amazing as melee type only. But i have every melee character already!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
