Hey guys hit up Sydney Dragway last night in my R33 GTS25t and ran a few times but my best seemed to be around the 12.7 mark and did that afew times down . Thing i wanted to know is that i did a 12.76 @ 89mph with 276RWKW . Is that a normal time for a r33 that i recently weighed at 1480kg Tare weight , and why is my MPH so slow for a 12 second pass?? shouldnt i be up around 100mph+
https://www.sau.com.au/forums/topic/335301-276rwkw-r33-1276-89mph/
So you've read your timeslip wrong - its 113mph
You don't have 280rwkw, that's for sure - MPH bit low. :D
Your 60ft time isn't too bad for street tyres either. If you could get it closer to 1.9 or so... your ET would be around 12.4! :ermm:
Yeh i dont have 280rwkw i acually have 276rwkw and the video i have show's 12.76 @ 89MPH on the screen so yeh i dunno. thought it was abit low to be right lol so if i get better traction i could run lower time
MPH doesnt mean shit for what power i have , i dont even know what ur going out about your the one who pulled the 280kw figure out of know where . and it's been tuned at JEM for 276.7rwkw and my last dyno day at another dyno saw 272rwkw and i have papers to prove it
Dynos read different. I was running around that mph with around that power, which I have made several times on different dynos. I don't know what JEM use, but 270ish kw in a full weight R33 definitely stacks up to around 113mph on a Dynapack.
sorry but mph means more than you thing.
MPH is a function of horsepower.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
