the only diffrences in Group A blocks (O5U)and standard older type RB26 blocks are one water jacket is enlongated....this can be done to the older block all R34 blocks have this O5U type block
*edit*Actually...it may be O9U.....i have to check my RB26 history book....its out on loan at the moment....
https://www.sau.com.au/forums/topic/33589-nismo-n1-block/#findComment-672902
The information you've been given so far is incorrect.
There are 3 different blocks: cast into the side of the block are the letters
05U or 24U
The std. blocks tend to crack bores when you exceed 550 to 600HP.
The STANDARD BLOCK 05U is a thin wall casting, due to the larger water jackets around the bores. (comes third for desirability)
The N1 and all R34 v-spec 24U is a thick wall casting and has the smaller water jackets around the bores. (comes second for desirability)
The GROUP 'A' BLOCK 05U but is a thick wall casting and has the smaller water jackets around the bores. (comes first for desirability, but rare)
Look for a block with the smaller water jackets, near the treaded holes for the head bolts.
You can buy the N1 block from NISSAN at around $3400.
Phillip
p.s. You can also get fully sleeved blocks.....but thats another story.
https://www.sau.com.au/forums/topic/33589-nismo-n1-block/#findComment-674573
Just some info from http://www.pow.com.au/gtr_engine_specs.htm
This is an ex-Bathurst Group A heavy wall block.
When GT-R engines make big horsepower (600hp+), they have been known to split the standard block. You may be wondering why the inside of the block is white in color ?
It has been sealed with an epoxy coating so that the oil drains back fast and bits of cast iron cannot break from the inside of the motor and go into the oil system. The welsh plugs holes have been tapped, the original welsh plugs removed and replaced with screw in machined aluminium ones to prevent them from ever popping out when under pressure.
This block is a very very rare item. These heavy wall blocks are not available anymore and are irreplaceable!
https://www.sau.com.au/forums/topic/33589-nismo-n1-block/#findComment-679602
  • 3 years later...
05U or 24U
Phillip
hey mate ive got a n1 block
in perfect condition
ho muchcan i get rid of it for u recon
im tryin to get rid of it atm
ur saying $3400 brand new form nissan this block looks like its never been used
i know its a n1 block because it has 24u on the side of it..
https://www.sau.com.au/forums/topic/33589-nismo-n1-block/#findComment-3550333
You've opened 3 threads today asking the same question, stop spamming as you have already had your questions answered a number of times.
https://www.sau.com.au/forums/topic/33589-nismo-n1-block/#findComment-3550336
Man some ones going to buy the wrong block.
05U standard block
24U N1 block can be brought for $2500 from sau traders and dont think all R34 vspecs came with one.
RRR GT block best you can buy if you can find one dont go looking for change from $5000.
Brad.
https://www.sau.com.au/forums/topic/33589-nismo-n1-block/#findComment-3550737
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
