yes for a very limited time, 1 week starting tomorrow corner weight scaling of your car, get your coilovers set properly,we place the car on the hoist and put a scale under each corner on skid plates, running back to the main computer, we can the see how much weight each corner is pushing into the ground, set up the balance of front to rear, side to side and cross corner balance, approximate the drivers weight in the seat and half a tank of fuel, $400-$500 depending on time need the car for a day we have to piss fart around a bit doing it. get your booking in limited time limited spots, i already have 3 cars booked.A must have for any track car or spirited street driver. 97923717 or by pm or post
sorry, advertising by unpaid traders is not allowed on SAU.
please either register to be a trader, or set up a "group buy" in the correct section http://www.skylinesaustralia.com/forums/Group-Buys-f61.html
Guest
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
