Anyone know how to run aircon diagnostics?
I have R32 skyline, and the aircon keeps turning itself off all the time. I have had it checked and was told everything is now fine except it stops blowing cool air for a while. The auto-electrician couldn't find out why, and said he had another one that does the same thing.
Any help anyone can give me will be greatly appreciated.
https://www.sau.com.au/forums/topic/3365-aircon-diagnostics/
Its a while since I've done this, so here goes:
Turn ignition to ON.
Hold down the (A/c) OFF button for about 5 sec. I think it starts having a 'flash' attack.
Use HOT / COLD buttons to move through the various diagnostic tests that it carries out.
Any errors will be flashed as a number after its all over.
Turn off ignition to cancel diagnostics.
Advice - make sure you park the car in full sunlight to avoid error 26 (sunlight sensor).
https://www.sau.com.au/forums/topic/3365-aircon-diagnostics/#findComment-56834
Compressor is now fine...did have aproblem but it is now sorted. The problem I now have is ever five minutes or so the a/c blows outside air in, not cooling it.
Auto electrician said it is most likely a sensor somewhere not working properly, and if i can find out how to do diagnostics it may help.
Thanks a lot blind_elk, will give it a go tomorrow, in the sunlight. Do you know what the different numbers mean?
https://www.sau.com.au/forums/topic/3365-aircon-diagnostics/#findComment-57258
NIZ30,
Should be getting word from my importer any day now!!,then I'll have a GTR front cut!!(but before they could send it but it fell off the forklift:mad: ,landed on the gearbox and nearly broke in two!)
Sure next time I see you in the centre parking, Ill stop to have a chat!!
MEGA
https://www.sau.com.au/forums/topic/3365-aircon-diagnostics/#findComment-59290
You should go out to the next meet at Benarby.
A class specificly for imports and 4's.
Should be real good, i hear people from bundy & rocky coming just because of that.
If i have a fourth gear by then i will come back for this. You should get decent times, 4wd and all.
Who's your importer?
https://www.sau.com.au/forums/topic/3365-aircon-diagnostics/#findComment-59299
Aria jap are the guys importing the front cut for me there in sydney!(couple of jap guys that don't talk much english though)
Yeah I could go but with no manual and turbo lag I would only get a high 15, so why bother to go if you only get laughed at!!!
By the way I crashed the R6(blue motorbike) two weeks ago!!! lucky to be alive today because I landed on my head after collecting a trailer!!(shh probably over 110ish impact speed)will lose licence though!! Not injured though! back at work the next day!!
MEGA
https://www.sau.com.au/forums/topic/3365-aircon-diagnostics/#findComment-59309
This must be the thread?
http://forums.skylinesaustralia.com/showth...highlight=garth
Thanks NIZ30 I will give him a call next time I need something!! I actually heard that there was a importer in Rocky but didn't know how to get in contact with them!
MEGA
:( :whip: :lol:
https://www.sau.com.au/forums/topic/3365-aircon-diagnostics/#findComment-60780
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
