Hi all,
I've got a set of 18x10 +19 Advan RA3-DT painted in black with internal drive lug nuts for sale.
Asking $1,000 as per title.
Located at Doncaster East (Eastern Suburbs, Melbourne, VIC).
Any questions or you want to grab them, PM me or text me on 0430 129 511.
Cheers
Grant
https://www.sau.com.au/forums/topic/336528-advan-ra3-dt-18x10-19/
  • Replies 46
Posted Images
the'll fit on the front of a gtst.... it's only 12mm more than what i'm running... and my guards have heeeeaps more in 'em
not to mention camber
meister s2r 18x10 +25, 18x10 +15, rash on the +25s and paint is coming off. +15s r good. i know its a longshot. will also throw in a free 18x9 +25 :)
Hmmm.........
Kinda tempting, straight swap yea?
meister s2r 18x10 +25, 18x10 +15, rash on the +25s and paint is coming off. +15s r good. i know its a longshot. will also throw in a free 18x9 +25 :banana:
Hmmm.........
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
