Reading an article the other day in Zoom i think it was a guy had an RB30/26 setup which i well known to everyone as is the head/block combos but after reading his setup infact he has a RB30 with a RB25 head with RB26 internals in the head now i wasnt sure if this was exactly possible i have heard of people saying "my RB25 head is RB26 spec or better" but not RB26 internals and if so how many other parts and internal parts are swappable?
I did search for this maybe just wasnt using the right words if there was somthin on it.
https://www.sau.com.au/forums/topic/336667-what-fits-in-what-rb-engine/
Just means he wasted time puttingh RB26 cams or something into a RB25 head - as that is all such a conversion is, waste of time :P
You can do anything you want really, just need money.
As for the mods actually being beneficial/worth the time, that is a whole other story.
Could it not also mean it was a RB25DE head and the valve springs were changed to RB26 items?
I think I read that was done somewhere in one of the hybrid build documents ive seen floating around. Dont ask me though.. i'll leave head building for my machine shop.
If you can get another look at it, it would be helpful. Look for the VCT solenoid next to the intake cam gear above the coolant out hose. If its there, (or removed and plugged), then you have a RB25DET head.
Otherwise its a RB25DE head (non vct), which is a direct bolt on to the RB30 block. As well as they use a similar valvetrain to an RB20, so they can be upgraded with RB26 parts. IE, springs, cams and lifters.
Rb25DET's use a hydraulic lifter so the 26 liftes arent compatible for that head.
Was it a car from Canberra?
If so, thats Fitspatrick SPeed Works (yes, he's on these forums every now and then)
i thought that car was running 26 head with a 25 block as they broke the 26 and had a spare 25 they werent using.
or is that one of the other ones?
RB20DET and RB25DE (R32 - non VCT) are hydraulic lifter heads aswell..
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
