Hi guys,
I just wanted to get some ideas on different chips for r32 gts-t's.
I am most likely going to get a dr drift one done in a month or so and I just wanted to hear from anyone if they noticed much of a difference in the overall running of the car.
At the moment I have 145rwkw's on 13psi, i got a cooler, xaust, pod, 044 pump...
With the new chip am i likely to gain any kw's?
What chip are out there to get and wat would be best?
thanks
Mark
https://www.sau.com.au/forums/topic/33682-chips-for-r32/
Hi Mark, you local Chiptorque or Fueltronics dealer should be able to tune your car in real time and burn the chip especially for your mods. Off the shelf chip is never as good, because all cars are different.
https://www.sau.com.au/forums/topic/33682-chips-for-r32/#findComment-676698
SydneyKid: Excuse my ignorance, but when you say they'll "burn the chip"... do you mean they'll make a custom chip for your particular car (or atleast have the settings custom made for your car)?
Also: would you say it would be a wise idead to do mods like FMIC, POD, Zorst and any other little bits BEFORE getting this done? Or are they fully reprogrammable and it really doesn't matter? (obviously it'd be cheaper to tune the car once rather than 5 times...)...
How much would i be looking at for this? how much gains?... (i'm guessing the gains would simply be in having a better a/f ration etc?)...
https://www.sau.com.au/forums/topic/33682-chips-for-r32/#findComment-678990
kool... i really wouldn't have a clue what teh right a/f ratio is... just that the guy on the dyno day said i should have mine leveled off to about 11.6.... so yeah, that's all i was goin off... how much of that gain was in the chip and how much was in the extra boost do you think?...
https://www.sau.com.au/forums/topic/33682-chips-for-r32/#findComment-683668
160kw at the wheels just from a retune and remap?!?!?! that's an awesome gain (30rwkw)...  Or does that include FMIC, POD and Zorst?....
yeah basic stage 1 upgrade, good fmic, pod?, full 3" system remap for ecu and a good tuner!!
https://www.sau.com.au/forums/topic/33682-chips-for-r32/#findComment-683764
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
