So my mate has a ba xr6t hes upgrading to a gt70 to go make 700rwkw, so he has the turbo from his car spare. would i be able to use it on my skyline?
I know i wouldent use it to its limits or even close but would it be worth my time getting it and putting it on.
considering im used to my car making 193rwkw with 10psi and turbo back exhuast.
and yes i know its a huge ass turbo but im still asking
https://www.sau.com.au/forums/topic/336913-xr6turbo-on-a-stock-r33-s2/
What model Xr6 is it. From my limited knowledge of these cars, the FG xr6's (approx 2008 onwards) had a 48trim 3076 compressor on a GT35 rear and the pre FG's (i.e. BF model) had essentially a GT35 front and rear - according to Nizpro. Both are internally gated. The FPV car's always had the larger GT35 turbo regardless of model.
You could easily confirm which turbo you have by measuring the inducer on the compressor. The ex wheel/housings were the same. Don't know what the ex a/r's are I'm sorry.
The FG turbo tops out around 300rwkw to 320rwkw when bolt on upgrades are applied depending on dyno. The pre FG turbo/FPV turbo is capable of 400rwkw tops. These figures are based on Ford 6 dyno's through the ZF 6 speed semi auto.
The FG turbo is probably the pick of the two for your car if it can be had for cheap. Otherwise just buy a 56trim 3076 with the GT30 rear as the GT35 rear might be an unkwnown quantity on your car with smaller displacement.
I recently picked up an FG G6E turbo (smaller turbo) and its fairly punchy on the big 6 as you would expect. Torque hits early in the rpm range (Ford claims 2000 rpm) and is capable of propelling these hefty cars down drag strip in sub 13 seconds for a stocker which isn't bad for an engine that has the characteristics of a diesel :D .
Edited by juggernaut1
a GT60 turbo is capable of 2000hp, they dont even list a GT70 model.
XR6 turbos are a waste of time on a mild motor - least of all one without the 10k in supporting mods required.
And by the time you have all the supporting stuff in place there are better turbo combinations to get anyway!
If you know its going to be epically laggy, how then does it mean the time/effort is worthwhile?
Some people's logic makes me wonder sometimes :whistling:
haha yea il try n get it for free dont reckon though.
and yes there is a gt70 still very new its mentioned here http://www.turbomaster.info/eng/turbos/gta57-70.php
yea i was just checking to see that it is a complete waste of time. and i knew it would be massivly laggy but i figured anything is better than the stock turbo even if it had lag figured it would still pull harder than the stock turbo
Pull harder from 5000rpm maybe. By which stage you are pulling a gear by around 7000rpm and probably on the cusp of boost so it'd almost be slower :D
Get a nice 3071/3076 like everyone else IMO.
If XR6 turbos were good upgrades - everyone would be doing them :whistling:
totally a waste of time and would never work, were is your proof as you always ask ?
around 6 min they say what turbo and power, thus proof for not being a waste of time !
Edited by PROXIMITY
you also seem to have missed that it was a 3L not a 2.5L.
just because it can be done, doesnt mean it should be.
In bold for truth.
Chris had some excellent results for the budget. The setup wasn't build to be the best of the best - it was built for the purpose.
There is nothing to say it cannot be done better, or that it was the best setup.
It was functional, and did what was required - but how does that help the OP? Not much.
Different motor, different level of mods, different use of the car...
dont mean its a waste of time wither like said, so bang for buck i think its worth it.
270 on a Na bottom end is nothing to complain about .
i didnt realise thatr when you purchased a turbo capable of certain kw you had to get that from it or your wasting your time.
And wow 500cc difference, bit like putting a rb25 turbo on a 20 results are not far off !
people just so quick to flame others on here, i gave a link to proof for sumeone asking about this turbo, yes i know the engine is 500cc difference but still a reference non the less !
not quite a 1000 rpm, my gt35r 0.82 was on 23psi at 4200 on my 25, and like 3550 25/30.
its alot of time and effort putting it on the car only to find out your not happy with the laggggg, as ash mentioned you would have to spend alot on bolt on mods and even then youd need to forge the engine to use the turbo fully. The turbo is only a small part of the total expense required to get the car to that level, if i was going to spend that much i would make sure i was happy with the turbo choice.
Jarrod
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
