Originally posted by PVL-747
will be there friday, saturday and sunday helping Subzero with their stand and dyno. they are bring along a few nice skylines and a fat Supra.
hey, u r friends with the subzero guys right.. is it true that the workshop got shot up by some gang recently.. or was that just someones rumour to stir trouble?
https://www.sau.com.au/forums/topic/3370-autosaloon/#findComment-57282
no it's true, as I know a guy, who goes to tafe, with some who works at sub-zero.
https://www.sau.com.au/forums/topic/3370-autosaloon/#findComment-57344
Baz. i think you don't know what your talking about. i see you don't like Mario. wow another smart comment. i take it you've meet him too?
If Mario is Micks brother, then he seems to be a great guy. Ive had no probs with him.
https://www.sau.com.au/forums/topic/3370-autosaloon/#findComment-58463
Well, after hearing nothing but bad things about it (mostly by ppl who didn't even go) I rocked up on Sunday arvo somewhat bleary eyed from the night before.
To all who didn't go, I feel you may have missed out. Once again, the guys from Cabin put on a great show. Sure, bodykits, wild paint and loud music may not be everyones cup of tea but jezz there were also some big HP cars there.
Oh, and the promo girls are always a high point! *drools*
https://www.sau.com.au/forums/topic/3370-autosaloon/#findComment-58723
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
