hey guys got these parts left from my shell need them gone asap!
ONLY got these parts left, don't even bother asking if i got something else I'll just simply ignore you glare.gif
located in Mulgrave 3170 (Vic), willing to post the smaller stuff.
- stock turbo(missing actuator) & dump pipe: $140
- stock front pipe: $50
- throttle body sensor [tps]: $50
- pipe that goes from turbo to afm: $30
- bov return pipe: $50
- turbo heat shield: $40
- injector resistor: $40
- drive/fan etc. belts all 3(brand new): $50
- power steering reservoir: $30
- battery: $60
- wiper/washer bottle: $40
- AC fan: $60
- 1 stock coil pack: $30
- oil dipstick: $15
- airvent that goes from airbox to front of bonnet: $30
- driver seat: $90
- passenger kick panel: $25
- under dash trim panel: $25
- dash cluster surround: $30
- demister switch: $20
- hazards/tune switch: $20
- AC Unit: $70
- AC/ heater blower motor: $80
- brand new front rotors(gone orange from sitting outside): $90
- orange passenger indicator(slight crack and scratch, still works): $40
can provide pictures if needed..
thanks.
Edited by wAAA`
https://www.sau.com.au/forums/topic/337077-r32-gtst-parts-melbourne/
bump
- battery: $60
- AC fan: $60
- oil dipstick: $15
- driver seat: $90
- AC Unit: $70
bump
- battery: $60
- AC fan: $60
- oil dipstick: $15
- driver seat: $90
- AC Unit: $70
bump
- battery: $60
- AC fan: $60
- oil dipstick: $15
- driver seat: $90
- AC Unit: $70
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
