Hi guys,
got car checked tonight at BP Newton whilst filling up
the officer was a decent guy
he mostly had a look at the engine and found a few little things which needed to be fixed up
the fine was $700 but he let me off with a warning and guaranteed me that we would meet again
one was my old non turbo canister hadnt hooked up to the new turbo engine emissions hoses and two were still unexposed
he said it was polluting the emissions into the environment
he also found these 3 things within my engine bay which i have no clue to why/what is wrong with them
do any of you guys know why the lead off the fuse box isnt connected up? also why that lead has a screw also cable tie in the end and my pod was bolted down but he said it was a mod? do i need a heat shield box? also he pointed out i need a stock boost solenoid/controller within my engine bay and brought to my attention the problem with my shit fuel economy is due to not having one! is that correct?
cheers
https://www.sau.com.au/forums/topic/337111-unknown-defects/
not really sure what your trying to show us in the last picture
the first one is easy take the zip tie off and bolt out and put on the end of the thing there i circled it
2nd pic change the red hose for black hose makes things stand out less
https://www.sau.com.au/forums/topic/337111-unknown-defects/#findComment-5451180
The third picture is the plug for the ABS sensor. there will be another one the other side. They dont need to be connected there just there in case ABS was an option on your car.
https://www.sau.com.au/forums/topic/337111-unknown-defects/#findComment-5451224
$700 for what?? am i missing something? driving a turbo car on your P's perhaps?
Nah i got my P's before the new law came in. The $700 was for the emissions to the earth due to not having the carbon canister hooked up to 2 exposed connectors
ok so will it affect my engine if i connected it? also due to it being an ABS hose and i dont have ABS does it still mean i could get defected for it in the future?
yeah i probably will do that tomorrow so it doesnt stand out
cheers for the help appreciate it alot
Breach of ADR's
exactly right
ok so does this need to be connected? Is it a future defect?
cheers appreciate your help
https://www.sau.com.au/forums/topic/337111-unknown-defects/#findComment-5451286
PERSONALLY, i would be going to the cop shop to discuss the fine for the abs plugs not being connected..
fare enough u need the carbon canister connected, but i would be asking why u have been fined for a factory option which was not chosen..
https://www.sau.com.au/forums/topic/337111-unknown-defects/#findComment-5451315
ridiculous
I have that plug not going anywhere also in pic 3
i knew it because my mate's skyline has the same thing aswell.. does anyone know/confirm if this can be defected for? and what its meant to be connected to?
cheers for the help
yeah thankgod i didnt get defected or fined for it.. ye exactly i know thats my fault for the canister and solenoid but the other things were a tad over the top.
cheers for the help
whats the story with that past pic with the bolt in the hose?
the stageas boost cut solenoid things around that area... might be blocked due to running high boost one day.
you reckon? the engine wasnt installed so it would run high boost. it was installed on a standard setup. but im guessing it shouldnt matter if i connect it back up
cheers for the help
wow, it looks like the officer had some knowledge
yeah he was from the hoon task force.. he knew his stuff but picked on things which weren't necessary/needed to be connected. but he also picked up stuff which he needed to. in the end he was just doing his job guess
Do you guys reckon i should go to a mechanic and get in writing the plug off the fuse box isn't a necessary/needed feature within the car and get him to attach a number to confirm this?
cheers for all of your help!
https://www.sau.com.au/forums/topic/337111-unknown-defects/#findComment-5451973
If you didnt get a sticker on the window, I wouldnt worry too much Domenic. Tidy the bits up that the guys have mentioned and you'll be fine.
Even though the officer pointed out bits like unplugged sensors, it doesn't necissarily mean he knows what he's talking about. Tuck them out of view so there's nothing to pick on.
The usual deal to keep in mind - if an officer thinks something is defectible, he'll ping ya. And the party starts there!
https://www.sau.com.au/forums/topic/337111-unknown-defects/#findComment-5452408
Just connect what's meant to be connected or hide it better.
If a cop want's to defect you they will.
The 180 I bought was defected for not having a gill fitted (yes, its written on the defect paper) and anyone who know's 180's know that they don't have grill's lol.
https://www.sau.com.au/forums/topic/337111-unknown-defects/#findComment-5452484
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
