Hey guys, I jus got a Alpine v12 amp and 12 inch sub. Now i have a dilema. What do you guys would be the best set up for a R33. Like i want to know what would give out punchy bass; a fully sealed and boxed sub box or the standard type sub box (where you can see the sub). Space is not a issue for me cos there is nothing ever in my boot anyways. I am hearing conflicting views on what is the better type sub enclosure. I know with home theathre systems almost all are fully enclosed now days. Anyways i thought id put this question forward b4 i chose one next week. Your opinions will be much appreciated. Thanks guys.
The best type of enclosure is the one that suits the type of sub you bought. If it's an alpine 12"? they come with an installation sheet that recommends what type of enclosure suits it.
Post the exact model and someone should be able to advise you what will work best.
Hey guys, thanks for your replies so far. Well the sub is a Alpine type S sub (12 inch and the amp is a Alpine V power amp and has a RMS of 350 Watts. So its not 2 bad. I like punchy bass and i usually listen to R&b and Hip hop and a bit of house music. So what you guys reckon?
When mentioned "fully enclosed" and "semi enclosed" be was reffering to:
Fully enclosed: Front and rear chambers (unable to see sub at all, just looks like one massive box with holes, useally twice the volume of a standard sealed unit)
Semi enclosed: Only has one sealed chamber, able to see either the front of the sub (most common), or the rear (sub fires into the sealed box)
If you have a great designer, and someone that is capable of building a strong box to exact specification, i would choose the band-pass design (fully enclosed). When designed and built properly, these enclosures produce the deepest, loudest and cleanest bass.
Design and build quality is vital.
hey guys,
Thanks for all ya replies so far. I think im leaning towards a fully enclosed sub box. My mate did his one and it sounds pretty good so i will get him to make me a box. he has some kinda fibre fill to insulate it as well. I love my clean bass rather than the "oomf oomf look at me" kinda bullshit. Anyways i also checked out the Alpine website and they got some info on it:
ALPINE Type-S SWS-1241/D 12" Rec Volume for sealed box 35 litres @ 49Hz
also adds:
Sealed enclosure volume includes heavy layers of dacron or similar fibre 'fill' and allows for displcement of the woofer. This is internal volume of box to build for effective in-car performance (Qtc 0.58 - 0.82). Sealed box volumes can also be varied.
You'll definately need an enclosure for that sub. The big question is sealed or ported? I am leaning towards a 'low frequency tuned' ported enclosure due to your power levels and music types. How much boot space can you spare champ?
I would probably tune the enclosure to 32hz but the enlcosure will be a little large (like around 1.5cf).
Hey FHrx. thats the question i wanna know as well hehe sealed or ported. I was thinking of going sealed but u may have made me change my mind. i can spare the whole boot since i never put anything in there anyway hehe.
Hey guys, Finally got my sub and amp put it. It sounds exaclty how i wanted it to. went with the fully enclosed box in the end. thanks for all your comments and advice. If you wanna see pics, they are in the post below.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=34157
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
